Best F-body Shocks
Old Mar 29, 2005 | 09:57 PM
Slayer63b's Avatar
Best F-body Shocks
My shocks are shot. So I am looking at getting new ones tonight. So what are the best ones for the price?
Old Mar 30, 2005 | 10:07 AM
stereomandan's Avatar
Re: Best F-body Shocks
We don't have any struts on our cars, only shocks.
If you are looking for a good improvement, and are keeping stock springs, the Bilstein HD shocks are great. A set of 4 will cost around $325.
If you want to go very high end, look at Koni single adjustables.
You can call Sam at www.stranoparts.com and he'll be great to talk to. He helped me out a lot and I couldn't be happier.
Dan
Old Mar 30, 2005 | 10:30 AM
DiabloGT's Avatar
Dan
would they work good with eibach drag launch springs?
Old Mar 30, 2005 | 12:10 PM
They will work, but I'm not sure if it's optimum or not. The drag launch springs are pretty soft from what I understand, and the Bilsteins in the rear are somewhat soft too, so they might match up well.
Best person to ask is Sam Strano at the link provided above.
Dan
Old Mar 30, 2005 | 01:00 PM
Slayer63b's Avatar
Yeah, that is what i ment. As for spings my friend has a pair of lowering spings i plan on gettin. Not sure on the spring rate. but they will drop the car 1.6". So will they work good w/ that kind of setup. I want it to hook up and limit the amount of wheel hoop. But still be a great all around ride at the same time.
P.S. If I had to pick though i would lean towards being able to launch harder.
Old Mar 30, 2005 | 02:24 PM
If you want to launch hard, lowering springs is the last thing you want, and stiff lowering springs (which most are) is even worse. It prevents weight transer to the rear.
If you lower the car and want to launch good, you should get loewr control arm relocation brackets.
If you want to launch good, stay with your stock springs.
Dan
G-BODYT56
Jan 14, 2022 11:14 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
