Measuring wheel width ?
Old Mar 29, 2005 | 12:22 PM
N20Dave's Avatar
When measuring a wheel, in this instance a 17x11 SS style wheel. Do you measure from the inside of the bead to inside of bead or from the wheel lip to wheel lip to get the overall 11"?
I just got a set of Bogart road race wheels and I ordered the fronts in 17x11 to put 315's on. When I got them the measure 12" lip to lip and stick out of the fenders. Bogart says they measure their wheels from bead to bead. I'm trying to get this bogart in the same sizeas a 17x11 SS. Help. Thanks.
Old Mar 29, 2005 | 12:44 PM
Chris@Tires.com's Avatar
Re: Measuring wheel width ?
The wheels are measured from mounting surface to mounting surface, excluding the 1/2 inch lip on each side..
A 17x11 does physically measure 12 inches wide.
Old Mar 29, 2005 | 01:32 PM
There are a few guides to wheel measurements on the 'net, including at Tire Rack and at the Skulte sites, but the new one on the M/T site is pretty clear:
http://www.mickeythompsontires.com/t...ckspacing.html
You also need to keep in mind that while the "width" of the wheel between the beads is well defined, the width of the lip is a "variable", and can be slightly different from wheel to wheel. The AFS ZR1 replicas use a lip that measures 0.460", for example.
Old Mar 29, 2005 | 02:20 PM
N20Dave's Avatar
Thank you both. Is it possible that the aftermarket K-member and A-arms I have have moved the track out more than stock? It's an Agostino K-member and lower arms with BMR upper arms. I'm concerned as when I got the front wheels and put them on the car they appeared to stick out much more than I thought they would. Now granted, the car is on jackstands with no tires mounted on the wheels and possibly it's an optical illusion but I've seen 17x11's with 315's on the front of several F-bodys and they don't look bad at all. Mayby it's just me. BTW these wheels have a 49mm offset and when mounted just barley clear the spindle so they're in as far as they can go.
Old Mar 30, 2005 | 07:52 AM
1-bad-z28's Avatar
are you putting 17 x 11's on the front? Most people put 17 x 9 1/2's on the front and 17 x 11's in the rear.
Old Mar 30, 2005 | 09:00 AM
Might want to try a "search".... some of the "road race" guys are using 11's on all 4 corners. There have been a couple of threads recently, with offset info and links to pictures.
Old Mar 30, 2005 | 01:11 PM
1-bad-z28's Avatar
i'm asking him if he is putting 17 x 11's on the front. Why would i........"search".......... for it? I know that some people put 17 x 11's on the front for road racing, but most street cars with that setup put 17 x 9 1/2's on the front. I'm just saying that might be why his is sticking out in the front
Old Mar 30, 2005 | 02:30 PM
N20Dave's Avatar
There are quite a few people that have 11's all the way around. What I'm saying is that mine seem to protrude father out than other pictures I've seen of the same setup. However, I do not have SS wheels so I'm wondering if I measured everything correctly with this different type of wheel.
Old Mar 30, 2005 | 03:29 PM
mmmmmm... his original post said he bought "road race wheels and ordered the fronts in 17x11".... seemed pretty clear.
Old Mar 30, 2005 | 03:35 PM
Dave:
What is the measured backspace on the Bogart wheels? Which "17x11 SS style wheels" were you trying to match.... the 50mm offset (7.93" BS) or the 36.5mm (7.43" BS)?
Old Mar 31, 2005 | 09:53 AM
1-bad-z28's Avatar
i did'nt catch that
jasonduaine
Jun 4, 2015 09:29 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Jul 4, 2005 05:00 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
