Can you decode this rear axle code?
Old Oct 13, 2002 | 10:30 PM
BamaZ28's Avatar
Question Can you decode this rear axle code?
I think this is out of a 1986 Impala, the number I found is (8GF K044).... I can't find any codes that resemble this on the web. Is there a way to find out the ratio without counting the teeth?
BamaZ28
Old Oct 15, 2002 | 03:05 AM
chicane67's Avatar
November 4, 1984
As for the ratio, you can mark the yolk at 12:00, Then turn both axles at the same rate/time (if its an open diff) and count the amount of turns on the yolk. This will give you an approximate ratio. Well close enough to determine if its a 2.73, 3.08, 3.23, 3.31 or 3.42.
Old Oct 15, 2002 | 11:25 AM
BamaZ28's Avatar
Thanks,
I was beginning to think I would never know!
BamaZ28
QuickSilver02
Apr 7, 2015 11:12 AM
Chet1185
Feb 4, 2015 09:51 PM
4586
Jan 3, 2015 07:22 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
rockync7
Jan 1, 2015 05:10 AM
