Whoosh!
Old Mar 24, 2005 | 12:21 AM
vonmoldy's Avatar
Whoosh!
thats the noise my gas cap makes as I take it off. Is this bad?
it happens cold or hot if that matters.
Old Mar 24, 2005 | 12:26 AM
Pandamonkey's Avatar
Re: Whoosh!
It's just preasure releasing from the tank - nothing to be alarmed about.
Old Mar 24, 2005 | 07:34 AM
shouldaboughtthez's Avatar
Re: Whoosh!
Mine does it if I run the tank all the way down to bone dry.
Old Mar 24, 2005 | 10:12 AM
Z28SORR's Avatar
Re: Whoosh!
No, it's good. In fact if you loose the gas tank cap seal the car will not run properly. It's all part of the emision requirements.
Old Mar 25, 2005 | 08:40 PM
vonmoldy's Avatar
Re: Whoosh!
Oh good cuz i have an SES light that comes on and read an article where this was considered bad but i guess it depends on the car.
Old Mar 28, 2005 | 11:12 AM
Z28SORR's Avatar
Re: Whoosh!
Older car were vented directly to the atmosphere. If the vent line became clogged or crushed, the pressure in the tank would go down as the gas was burned. This could lead to vaporlock at the least and possibly a collapsed tank at the worst.
In modern cars the tank is vented to the exhaust emissions system which creates a slight vacuum on the tank. This is not a problem for the in tank high pressure pumps. Most owners manuals tell you to make sure that the gas cap clicks three time when tightening, or to make sure the cap is tight. The maintenance manual has you trouble shoot this for specific failure modes.
Rich Weigel
May 9, 2014 08:44 PM
blackrat
N2O Tech
Jan 10, 2007 02:30 PM
DanTheIROCMan
3rd Gen / L98 Engine Tech
Jul 15, 2003 05:31 PM
WhiskeyJack
Jul 11, 2003 07:44 PM
