Timing Question
Old Oct 13, 2002 | 04:17 PM
WadeC's Avatar
Question Timing Question
At WOT, my timing fluctates between 32 and 35 degrees, with no knock retard. Is it normal for this fluctuation, or am I looking at and opti problem. My car lately has had a intermitent dropping idle problem. Thanks.
Old Oct 13, 2002 | 06:56 PM
96z's Avatar
96z
Ive got almost Identical problems as you. PLEASE let me know if you find out what it is.
Old Oct 13, 2002 | 07:07 PM
WadeC's Avatar
I know so far, that I have no missfires, and my IAC and TPS are adjusted and working perfectly. This is what really makes me think I might need my 4th opti in 2 years. The timing fluctates even more at idle. I dont know if this timing fluctuation is normal at all times.
Old Oct 13, 2002 | 07:12 PM
95Blackhawk's Avatar
And this change in timing doe not coincide with a change in RPM vs MAP table changes?
Ben
Old Oct 13, 2002 | 07:37 PM
WadeC's Avatar
I havent changed anything in my programing since this started happening. The car didnt have these problems till 2 months after I programmed it with LT1 edit. My laptop battery died for good, so I have been using a Tech I to look at things. At idle maybe the timing fluctuation is due to the rpm fluctuation, but at WOT, the timing fluctates up and down through all rpms.
Old Oct 13, 2002 | 08:25 PM
96z's Avatar
96z
Well my symptoms include a jumpy, fluctuating idle, the car seems to pull half *** in the upper RPM's, and sometimes it wants to stall at lights. Ive also had a multiple or random misfire code although no actual misfires have been detected when datalogged.
I just had my opti replaced too. I dont want to put another one in.
Old Oct 13, 2002 | 10:09 PM
WadeC's Avatar
Fuel problems can definently cause your syptoms. Other than than fuel or a bad MAF/IAT, I have no other simple ideas what would be the problem. Have you checked fuel pressure?
Old Oct 13, 2002 | 10:28 PM
96z's Avatar
96z
Yeah FP is fine, I just had a 255lph walbro put in.
Feffman
Oct 9, 2015 05:42 AM
sscott
Jan 17, 2015 04:30 PM
capebuf
Jan 13, 2015 07:22 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
