Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
99 Cobra?
Old Mar 20, 2005 | 07:37 PM
ChevyTuffD.A.'s Avatar
99 Cobra?
My best friends sister said she knows a guy thats real cocky about his Mustang and likes to race. She called him up last night and asked him about it but he was out of town for the weekend. He asked what year camaro I had and she said 95 and he instantly agreed to it. We told him my car was stock What do the 99 Cobra's run?
Old Mar 20, 2005 | 08:43 PM
camarolover20's Avatar
Re: 99 Cobra?
You should take him i m pertty sure 96 to 99 had 4.6 with dohc and they ran 14.0 flat stock i seen one at the track with just flow masters ran 13.9 at 101 reason i watched i almost found a 96 for 6 grand and almost jumped on it but test drove it and the guy beat the hell out of it
Old Mar 20, 2005 | 08:51 PM
Roller406Bu's Avatar
Re: 99 Cobra?
A 99 cobra will run 12 second times with 4.30's and exhaust..You will lose if he knows how to drive it........
Old Mar 20, 2005 | 09:02 PM
Re: 99 Cobra?
He better be one damn good one if it isnt supercharged witch i didnt think 99's were.Did you see chevy tuffs mods it isnt a stock car
Old Mar 20, 2005 | 09:53 PM
Re: 99 Cobra?
99 only had 320 hp, less if it was never takin back for the recall. 99's are not supercharged. I highly doubt this kid runs 12's.
Old Mar 21, 2005 | 04:58 AM
SFB767's Avatar
Re: 99 Cobra?
'99 Cobras with "The Fix" should run about mid-to-high 13s.
Old Mar 21, 2005 | 08:03 AM
Fallstar01's Avatar
Re: 99 Cobra?
To clear a few things up, the 99 cobra runs mid 13s... It's slightly slower than Mach because it has the IRS... I'm pretty sure it runs faster than the 98 even though the 98 had the regular axel. There are no blowers on any mustangs except the 03/04 cobra. Options to look out for: Any aftermarket blower would most likely be centrifugal. FR500 Heads and Intake are a nasty upgrade for those cars. It's important to note that those cars cant support more than 425 or so hp without rebuilding the engine. (03 cobra, however, is forged and supports up to 650 safely).
Old Mar 21, 2005 | 09:35 AM
Re: 99 Cobra?
Whatever haters..I run 12.89@106 and I don't have a damn supercharger. Cobra's put down more rwh than I do so they can run 12's easier than I can.....On the other hand if the car is stock then you guys are right on, mid to low 13 for a stocker........
Old Mar 21, 2005 | 07:02 PM
Antz97ZNJ's Avatar
Re: 99 Cobra?
Mid to higher 13's w/ your average driver....some have hit lows...w/ gears and tires they can hit 12's
Old Mar 23, 2005 | 03:34 PM
grannycar's Avatar
Re: 99 Cobra?
well..the 99's are complet dawgs even when fixed compared to the 2001 n/a cobra..i have a ford article that befor the fix it dynoed at 236rwhp and 259rwtq ish..after the recall only dynoed at 260 and 275ish.. compared to the 01 which dynoed at 270 somthing and 285lbs..they couldnt even break the 99 into the 13's stock..it ran like 14.3 at 95-96.. and the o1 ran 13.5s at 101..somewthing like that..you should have no problem with it..
Old Mar 23, 2005 | 05:52 PM
toneloc12345's Avatar
Re: 99 Cobra?
there is a guy around here that has an '01 cobra with intake exhaust and 4.XX gears, he runs consistent 13.5's
TONY
Old Mar 23, 2005 | 07:31 PM
Antz97ZNJ's Avatar
Re: 99 Cobra?
Originally Posted by grannycar
well..the 99's are complet dawgs even when fixed compared to the 2001 n/a cobra....
Go tell Bob Crosby that. Regardless of what magazine you might of read that comment couldnt be any farther from the truth...After the fix the 99 and 01's performance are closely comparable and in the right hands a 99 is capable of any stock or modded time a 01 can accomplish.
Old Mar 25, 2005 | 11:48 AM
95Z-Cross-Eyed's Avatar
Re: 99 Cobra?
I ran a 13.05@105.89 with only 1.94 sixty in my 95 convertible Z, which is now sold. Car had over 100,000 miles only mods where: CAI, Mac shorties, crane ignition, and an air foil <-- wanna list everything, and a high flow cat. Now this is a convertible, ChevyTuff has more mods. Are the times in your sig. with those mods? Just curious because my 1/8th was a 8.4@83.7. Im just saying Lt'1s can definately outrun a 99 cobra and get in the 12's fairly easily as well. Gotta remember the driver mod. This was a 6 speed car as well with factory clutch. Ohh one last thing nothing removed from car execpt jack and spare tire.
Just race him and see what happens. Those are a close match-up and alot of times becomes a drivers race.
Mike
Old Mar 25, 2005 | 02:15 PM
Bob Cosby's Avatar
Re: 99 Cobra?
"Fixed" 99 Cobras dyno about the same and run about the same as 01 Cobras. High 13s is pretty regular, with the better drivers/conditions seeing mid 13s.
Old Mar 25, 2005 | 03:27 PM
grannycar's Avatar
Re: 99 Cobra?
sorry for the misunderstanding then..guess 99 are about the same then..
