99 Cobra?
99 Cobra?
My best friends sister said she knows a guy thats real cocky about his Mustang and likes to race. She called him up last night and asked him about it but he was out of town for the weekend. He asked what year camaro I had and she said 95 and he instantly agreed to it. We told him my car was stock
What do the 99 Cobra's run?
Re: 99 Cobra?
You should take him i m pertty sure 96 to 99 had 4.6 with dohc and they ran 14.0 flat stock i seen one at the track with just flow masters ran 13.9 at 101 reason i watched i almost found a 96 for 6 grand and almost jumped on it but test drove it and the guy beat the hell out of it
Re: 99 Cobra?
Originally Posted by Roller406Bu
A 99 cobra will run 12 second times with 4.30's and exhaust..You will lose if he knows how to drive it........
Re: 99 Cobra?
To clear a few things up, the 99 cobra runs mid 13s... It's slightly slower than Mach because it has the IRS... I'm pretty sure it runs faster than the 98 even though the 98 had the regular axel. There are no blowers on any mustangs except the 03/04 cobra. Options to look out for: Any aftermarket blower would most likely be centrifugal. FR500 Heads and Intake are a nasty upgrade for those cars. It's important to note that those cars cant support more than 425 or so hp without rebuilding the engine. (03 cobra, however, is forged and supports up to 650 safely).
Re: 99 Cobra?
Whatever haters..I run 12.89@106 and I don't have a damn supercharger. Cobra's put down more rwh than I do so they can run 12's easier than I can.....On the other hand if the car is stock then you guys are right on, mid to low 13 for a stocker........
Re: 99 Cobra?
well..the 99's are complet dawgs even when fixed compared to the 2001 n/a cobra..i have a ford article that befor the fix it dynoed at 236rwhp and 259rwtq ish..after the recall only dynoed at 260 and 275ish.. compared to the 01 which dynoed at 270 somthing and 285lbs..they couldnt even break the 99 into the 13's stock..it ran like 14.3 at 95-96.. and the o1 ran 13.5s at 101..somewthing like that..you should have no problem with it..
Re: 99 Cobra?
Originally Posted by grannycar
well..the 99's are complet dawgs even when fixed compared to the 2001 n/a cobra....
Re: 99 Cobra?
I ran a 13.05@105.89 with only 1.94 sixty in my 95 convertible Z, which is now sold. Car had over 100,000 miles only mods where: CAI, Mac shorties, crane ignition, and an air foil <-- wanna list everything, and a high flow cat. Now this is a convertible, ChevyTuff has more mods. Are the times in your sig. with those mods? Just curious because my 1/8th was a 8.4@83.7. Im just saying Lt'1s can definately outrun a 99 cobra and get in the 12's fairly easily as well. Gotta remember the driver mod. This was a 6 speed car as well with factory clutch. Ohh one last thing nothing removed from car execpt jack and spare tire.
Just race him and see what happens. Those are a close match-up and alot of times becomes a drivers race.
Mike
Mike
