Rear Install... in driveway...
Old Mar 16, 2005 | 07:08 PM
CreatiVe2's Avatar
Lightbulb Rear Install... in driveway...
i know it possible, but can it be done in a weekend? in a garage? and if so... would i need a spring compressor? or any other specialty tools? my friends 95 camaro rear is basically dying slowly... he has a brand new rear matched up and ready to go... i just want to know if it would be practicle to do it in a garage with a few friends... or pay to have a shop do it...
Old Mar 16, 2005 | 07:11 PM
Flamed Z's Avatar
Re: Rear Install... in driveway...
I've changed mine out 3 times once by myself its not the bad.....should only take a few hours.....good luck
Old Mar 16, 2005 | 07:14 PM
Pasky's Avatar
Springs on the rear are not compressed nearly as much as the front, the rears practically fall out.
Old Mar 16, 2005 | 07:18 PM
wb3s94z28's Avatar
Very possible, it takes me (by myself) about 4 hours from jacking to car to driving it out of the driveay. No spring compressors, just need a jack and two jackstands with basic hand tools. Somethings from experience:
1) the loops that hold the brake line on the rear, bend them back and hank the calipers with bailer wire or a wire hanger.
2) unbolt the struts first, then panhard, driveshaft, torque arm, and finally the lca's. I have found it eaiser that way, also when i install it i work backwards from where i started.
3) if it has never been taken out have alot of wd-40 or whatever you use to brake loose bolts. The swaybar endlinks, if they are old, never fail to break! I'd soak all the bolts in wd-40 or whatever about 5-10 mins before you start to tear it down.
4) BE ORGANIZED.... not too much you can switch around, but i hate loosing bolts so when i take them off i put them back into on of the parts and just screw the nut on so it stays.
5) when lowering it, be carefull of the springs, do it moderatly slowly. When install the springs, jack it up so their is little pressure, but enough that you can turn the spring in the boot and here it rest aginst the indention in the boot.
Ummm....i think thats about it, i might be missing something, but its a learn as you go process. 2 guys, shouldn't take you more than 8 hours to swap a rear.
Old Mar 16, 2005 | 07:20 PM
95_LT1_6SPD's Avatar
I just came inside from installing my rear. Took me about 1.5 hours to install Gas tank, heat shields rear end and button everything up. Its a cake walk man, a cake walk. The post above is pretty good.
Old Mar 16, 2005 | 08:10 PM
CreatiVe2's Avatar
guys thanks for the quick responces and positive feedback!!
wb3s94z28, welcome to the board and thanks for your input! it will be very helpful... i didnt relize this many peopel have swapped out their rear! ahahh
Old Mar 16, 2005 | 08:26 PM
wb3s94z28's Avatar
The pleasures all mine! Hope your rear turns out great, i imagine it will. And thanks for the welcome
Old Mar 16, 2005 | 08:37 PM
Fuels94TA's Avatar
Took about 4 hours myself. It's very easy, with all basic tools. In my case I had a air compressor to help. I even got a couple of pics before and after shots of the rear in my site.
Old Mar 16, 2005 | 08:41 PM
BoltOnZ's Avatar
I had one out and the other in in about 3 hours with regular hand tools...its not too bad
Old Mar 16, 2005 | 09:54 PM
Z95m6's Avatar
I think it took me 4-5 hrs to swap mine by myself. That included swapping my brakes and axles over into the new rear before installing it. Very easy to do in a home garage. Just make sure you have a break over bar and penetrating lube.
Old Mar 16, 2005 | 09:58 PM
1quikZ's Avatar
2 1/4 for me to the final bolt, (had a buddy give me a hand tho)
Old Mar 17, 2005 | 12:20 AM
tanker's Avatar
dam, that's fast. It took my brother and I (second time doing for me), both working very efficiently ~4hours, including the time to put the car on the ramps. Good time
Old Mar 19, 2005 | 04:03 PM
CreatiVe2's Avatar
wow... we are taking the old rear out now... and when we took the calier off that was grinding on the rotor, on the drivers side... the axle PULLED RIGHT OUT! NO clip inside the posi unit to hold it on!!! wow... i cant imagine what damage was done to this rear! i will post more later when the job is done
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
thenewkid
Apr 12, 2015 07:42 PM
