TH350 conversion complete now car wont start
Old Mar 12, 2005 | 09:55 AM
meangrn94ta's Avatar
when i started the TH350 conversion i knewi had a bad starter so i replaced the starter since it had to come out anyway. with everything reasembled the car will not turn over or click. when i put the TH350 in i also replaced the shifter with a hurst quarterstick, this is where i think the problem is. i hook up what i thought was the neutral safty switch but up i not sure if it is the right one because the car still wont start. so does anyone know which color wires are for the neutral safty switch. any help would be great thanks.
Old Mar 12, 2005 | 10:29 AM
Bone Daddy's Avatar
Re: TH350 conversion complete now car wont start
Look on the old shifter, find the switch. Then, look near the console area for a plug and harness that would fit it.
You've just found your wires.
Now, use a paperclip or a piece of copper wire to jump the harness connectors. If it cranks, then your Hurst switch is DOA. If it doesn't, well.. you have other problems.
Old Mar 12, 2005 | 05:59 PM
thanks bone daddy i wend toi a friends website and found it on there. the neutral safety switch is the bir yellow and big brown wires. the website is www.shootmyphoto.com/moser
Queens94z28
Dec 20, 2014 09:11 PM
NewsBot
Dec 3, 2014 12:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
