Head Gaskets
Old Mar 12, 2005 | 12:32 AM
neil350's Avatar
Head Gaskets
Trying to keep mine alive on about a 150 wet shot, what should I do? The car is going to get tuned and I'll prolly be mixing some 104 in, also stepping p fuel pumps to a 255 Walbro, but I have heard of people poping head gaskets. I under stand head gaskets are like fuses and dont go out for no aparent reason, always a reason, so what should I do to avoid blowing mine? End goal is 11.5s with bolt ons and gas
Old Mar 12, 2005 | 07:22 PM
396D1SS's Avatar
Re: Head Gaskets
Everything you said sounds good to me spray the hell out of it
Old Mar 13, 2005 | 01:19 PM
chevyguy3's Avatar
Re: Head Gaskets
you dont need race gas for your combo. your head gaskets as well as the whole motor will be just fine with that combo as long as you dont lean it out. when people blow head gaskets its due to detonation which is either caused by too much timing, too little fuel, or a combination of both
Old Mar 13, 2005 | 06:52 PM
neil350's Avatar
Re: Head Gaskets
Yea, I'm trying to do this right, I like to race the car but I dont want ***** my car out or do things half ***, if that makes any sense. I just want a quick street car if thats possible.
Ok cool, thanks a lot. I have heard of people spraying 150 on pump 93, seems like detonation is the key thing to avoid. For head gaskets as well as the pistons.
Old Mar 13, 2005 | 08:23 PM
396D1SS's Avatar
Re: Head Gaskets
I sprayed a 175 shot on stock timing with 93 oct for 2 years
Old Mar 13, 2005 | 09:08 PM
rskrause's Avatar
Moderator
Re: Head Gaskets
The ubiquitous FelPro should be fine. If you aren't going to have the heads off for some other reason I would just stick with the stockers until (and if) there is a problem.
Rich
Old Mar 13, 2005 | 10:21 PM
MEAN_SBC's Avatar
Re: Head Gaskets
I'm runnin felpro "performance" gaskets and have never blown one... (300 shot )
I'm not sure what the part number is for your application, but the stockers should hold up fine on 150 shot...
Old Mar 14, 2005 | 01:28 AM
neil350's Avatar
Re: Head Gaskets
Motor still has stock head gaskets, only has 66K on the entire car, heads never been off nor have the valve covers would like to keep it that way for a while untill I'm ready for an upgrade.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
