High Stall Problem Possibly
Old Mar 9, 2005 | 02:39 PM
THEMADTYPH00N's Avatar
I just put in a 2800 stall converter my 95Z and I think I'm experiencing the High Stall problem. If I start the try to do a burnt out it will break them loose in first but as soon as I roll out of it the trans will shift to 3rd and never come out of that gear again. It also won't lock the converter. Sometimes before it even starts the spin the tires it will just shift to 3rd like that. This also happens when you launch the car hard. Sometimes it will run through 1st and then shift right to third. Other times as soon as you lay into the gas hard and it flashes the converter it will instantly go to third. Anyway after it gets stuck in 3rd like that if you shut the car off and turn it back on everything goes back to normal. I got out Datamaster and checked for codes. There where two "TPS LOW" and "OUTPUT SPEED LOSS". I checked the tps sensor with datamaster and it seems to be working properly. I'd also find it hard to believe that it would act up right after a converter install. Are these symptoms of the high stall problem? Or is this some other unrelated problem? Thanks
Old Mar 9, 2005 | 03:15 PM
94Zpower's Avatar
Re: High Stall Problem Possibly
yep thats the high stall prob or better known as the Stall wall, contact Brian at www.pcmforless.com he has the fix and can hook you up, the only side affect is that the car will not kick down from 2nd to 1st.
Old Mar 10, 2005 | 09:27 AM
1SlowFormula's Avatar
really?? I had bryan fix this for me, and he didn't mention that! Where did you get that info? When I get the car back together I need to test that out. But, I don't think I have tried to get it to kickdown.. Thanks for the info Gary!
Old Mar 10, 2005 | 09:39 AM
Oh yeah, to the guy that asked, I forgot to mention that yes this is a problem with the high stall!! Bryan says he can fix it, I had this problem but have not had an oppurtunity to see if it has been fixed, also just so you know this is also caused by internal problems in the tranny too.. Did you install a trany cooler when you did the converter? The heat will kill it quickly!
Old Mar 10, 2005 | 10:19 AM
94Zpower's Avatar
John,
Bryan himself told me this when I sent him mine, check with him about it
Old Mar 10, 2005 | 10:30 AM
Yes I have the biggest cooler B&M makes on the car.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alex5366
Mar 8, 2015 11:32 AM
slothgrant
Aug 22, 2002 03:01 PM
