sub/amp question
Old Mar 9, 2005 | 08:12 AM
One Tight TA's Avatar
sub/amp question
I'm about to have a Kicker Solo Baric L7 15 installed but I need to know if I should get a 2 ohm or 4 ohm. I don't know a great deal about audio stuff, the amp I am going to use is the Kicker KX800.2. If anybody knows about this amp and knows whether or not I should get a 2 or 4 ohm speaker let me know. I'd greatly appreciate it.
THanks
Clayton
Old Mar 9, 2005 | 10:18 AM
LS1 RULZ's Avatar
Re: sub/amp question
The minimum impedance for that amp when bridged is 4ohms.
Old Mar 9, 2005 | 10:27 AM
CamaroSS30thAnn's Avatar
wow 4 ohms , try going for an amp with a minimum impedence of 2 ohms or less
either way oit will sound great but u can get more power form less impedence
just dont try making that amp 2ohms or it wont last long, alot of amp will have a circuit protection if teh impedence is dropped below what it can handle
Old Mar 10, 2005 | 07:26 AM
Damn, that sounds like jibberish to me. I've spoke with about 6 different shops, and I get a different answer from everybody. I ended up ordering a dual 2 ohm voice coil L7 just because I went with the majority. So you're saying if you run that amp at 2 ohms i'm liable to burn it up faster than if it was at 4? Sorry guys i'm extremely ignorant when it comes to this ****.
Thanks,
Clayton
Old Mar 10, 2005 | 08:38 AM
LS1 RULZ's Avatar
If you will be bridging the amp then you must connect a 4ohm load to it. If you use the amp in 2 channel mode than you can run it into a pair of 2ohm speakers. Since this is for a subwoofer I assume you will be bridging the amp? In that case take your sub with dual 2ohm voice coils and run them in series for a final 4ohm load.
Very few 2 channel amps on the market today can handle a 2ohm load when they are bridged. A better amp option would be a mono Class-D subwoofer amp that can run at 2ohms without any problem. In that case you would need a sub with dual 4ohm voice coils ran in parallel for a final 2ohm load.
Old Mar 11, 2005 | 10:53 AM
Lions3's Avatar
It's not really the case that you won't be maximizing an amplifier if it's not run at 2 ohms. You need an amp that matches the subs you're using. Think of it as matching a cam to your motor application.
For example, my home amp is optimized for 8 ohm impedences. It will take a lower ohm load, but that means more heat and stress on the components inside. Sorta like using a huge cam on an otherwise stock motor. Won't run properly.
Your sub has a recommended power rating of 1000w RMS. Since you've decided to buy the dual 2 ohm sub, you need to find any amp that will produce that power at either 1 ohm or 4 ohms.
Good choices would include the MTX 7801 (If you can find a retailer with them yet) that delivers 1200w RMS At 1 ohm, a JL 1000/1 that delivers 1000w RMS at any impedence between 1.5 and 4 ohms, a Soundstream 1600.2 which delivers 1600w RMS at 4 ohms bridged and the list goes on and on.
Basically, find an amp that has a reputation for reliability and power output that produces the power you need at your final impedence in the price range you can work with.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
