SBC flywheels in an LT1
Old Feb 27, 2005 | 03:54 PM
disco192's Avatar
What makes LT1 flywheels so much different than standard SBC flywheels?
My motor is a neutrally balanced 383, so why couldnt I just use a SBC 0 balance flywheel with the right starter teeth and surface area?
Thanks,
Stu
Old Mar 1, 2005 | 05:05 PM
Lonnie Pavtis's Avatar
Re: SBC flywheels in an LT1
The old style SBC had a different bolt pattern than the later models with the 1pc rear main seal.
All 1pc rear main engines have counterweighted flywheels & are the same counterweight / bolt pattern as the LT1.
You would still need a special neutral balanced flywheel for your engine.
Old Mar 1, 2005 | 08:47 PM
OBE1 95Z28's Avatar
I believe the SBC flywheel is 168 teeth vs 153 teeth for the LT1. Also need to verify that the diameters are the same; I think the SBC is a larger diameter disk.
Noer
Feb 28, 2015 11:29 AM
Ringmaster72
Feb 25, 2015 03:15 PM
HectorM52
Jan 30, 2015 11:08 PM
Nostang 96z
Sep 15, 2002 10:15 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
