Stock to aftermarket wheels
Old Feb 21, 2005 | 03:01 PM
Infinity2134's Avatar
I have the horrible steel wheels with the hubs on them. The tire is a 215/60/16. I was wondering what size wheel these tires would work on. Do I have to stay with 16 or will they go to 17? Will they only transfer to 16X8? Thanks in advance.
Josh
Old Feb 21, 2005 | 03:34 PM
Re: Stock to aftermarket wheels
Your 215/60-16 tires can ONLY be used on 16" diameter wheels.
How wide a wheel they will fit on depends on the manufacturer of the tire. Some manufacturers recommend no wider than a 7" wide wheel for that size tire. Other manufacturers will allow that tire on up to an 8.5" wide wheel. You need to check the manufacturer's recommendation for wheel width.
Old Feb 21, 2005 | 04:00 PM
I researched a little and they only allow 6.0-7.5 wide rims. What options do I have with that? Any suggestions without having to buy new tires?
CamaroHeed
Mar 18, 2020 09:50 PM
canbaufo
May 25, 2015 12:01 PM
chuyz28
Nov 25, 2014 11:14 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
