i need a new carrier
Old Feb 19, 2005 | 01:50 PM
slammed95cam's Avatar
i have a 95 3.4 camaro.... i blew up my ring and pinion gears..... the previoous owner put in Richmond 3.73s and an Auburn LSD............... since i shattered the gears i was told i would need to purchase a new carrier..... where can i find one on the net??? i also want to still have LSD.... so i need to purchase another LSD or can i use my old one?????
my carrier is a 3 series...
thanks
Old Feb 19, 2005 | 01:52 PM
Re: i need a new carrier
i have Motive 3.42 gears and an install kit already..... i just need to know what else i need
Old Feb 20, 2005 | 06:15 AM
Pro Built Automatics's Avatar
Is your carrier an Eaton or an Auburn?
Old Feb 20, 2005 | 12:06 PM
92RS305#2's Avatar
you prolly damaged the ring mounting spot when it shattered. i have a 2-series open carrier thats still in good condition but i don't think you'd want that one wheel wonder. and it can work with larger gears you just need a special spacer/adapter.
Old Feb 20, 2005 | 01:24 PM
i just wanted to know if a carrier and a LSD are 2 different things.......... the guys at Thunder Racing told me that a LSD is a carrier itself..... so i just have to buy a Eaton/Auburn/Zexel LSD and slap my R&P gears on it and throw it in.....
Old Feb 20, 2005 | 09:56 PM
92RS305#2's Avatar
the limited slip just describes the clutches located in the carrier itself. so yes buy a new limites slip carrier, new ring and pinion, and i'd go with some new bearings why your at it. even though your current bearings may be in good shape what can it hurt?
blkss01
Mar 29, 2003 02:36 AM
DTABFORMULA
Feb 28, 2003 04:56 AM
SnkEatr
Feb 24, 2003 11:30 AM
sideways_Into_3rd
Feb 16, 2003 12:24 PM
TransAm_Impostr
V6 Tech
Feb 15, 2003 07:15 AM
