Stock Offset For 2000 T/a?
Old Feb 19, 2005 | 01:01 PM
BLACKBIRD8200's Avatar
I plan on getting some new wheels soon and need to know the stock offset for a oo t/a convert.
the wheel i want are the new c6 black 5 stars there are 18-8.5 and i think the offset is 56mm. i just wondering if they will fit?
Old Feb 19, 2005 | 01:54 PM
Re: Stock Offset For 2000 T/a?
The stock wheels are 16x8" with 55mm offset. For an 8.5" wide wheel, and a 56mm offset, you will be adding about 0.3" to the backspace and about 0.20" to the frontspace. Wheel and tire will fit fine, no problems.
You might want to consider a wider wheel.... say at least the 18x9.5". You can fit wider tires, and it just looks a lot more aggressive. You could use an offset anywhere from 45mm (edge of tire near outer edge of fender) to 56mm (edge of tire about 3/4" in from the edge of fender).
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
jayvar
Feb 2, 2015 10:00 PM
Catmaigne
Dec 25, 2014 12:16 PM
