installed new rotors/pads, NEED HELP
Old Feb 18, 2005 | 06:16 PM
mrd96099's Avatar
ok i installed some cross-drilled and slotted rotors on all 4 and some Hawk HPS brake pads on all 4. Im hearing some friction kind off sound coming from the rear driver side rotor. i think the pads is slightly touching the rotor, and its giving off a low sound. will this go away??? cause i only drove it maybe a couple of miles after i installed it. i wasnt having problems with the caliper sticking or anything before. could it just be the new stuff just settling in??
this is what i did today, i took the whole rotor and pad and everything back apart to see if something is wrong, but then i put everything together and its still making the noise. I then checked if the caliper was sticking, so i dropped it in NEUTRAL and with some help was rocking the car back and forth to see if the brake pad was touching and it wasnt. so i was like wth and put it back in PARK and did the same thing, rock it back and forth, and everything was fine. So could this be a messed up rotor??? or could it still be the caliper??? NEED HELP ON THIS
thanks for any help
Danny
Old Feb 18, 2005 | 08:04 PM
lastlaf's Avatar
Re: installed new rotors/pads, NEED HELP
Hi. Ya it is normal for new rotors/ pads to touch a little in the beginning after you have just installed them. Give them a few miles for break-in time and they should be fine after that.
Old Feb 20, 2005 | 07:21 AM
RE AND CHERYL's Avatar
When I installed the same parts on my car for a day or so the brakes sounded like a playing card in spokes when I applied the brakes. It wasn't very loud but it sounded wierd.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
