are my synchros gone?
Old Feb 12, 2005 | 12:52 PM
nin97's Avatar
i just got all synchros and bearings recently replaced...paid a good 1300$ almost to get it done
and just yesterday i think my first gear and third gear synchro went...when i put it into gear and let off the clutch it pops out
any help guys? could it be my stop bolts on the shifter? maybe they came loose
Old Feb 12, 2005 | 02:26 PM
SSBOY 2 N V's Avatar
Re: are my synchros gone?
First off I would check the linkages, for your clutch, before just thinking its the syncro's. Next I would check the clutch free pedal travel, if you don't know what that is, its the free play between the throw-out bearing and the pressure plate. Your pedal should have about 1 inch of free pedal travel. Hope that helps.
Old Feb 12, 2005 | 08:27 PM
nin97's Avatar
im an idiot
stop bolts on my short throw came loose...i realized this while i was going to bed last night lol that it might be the cause
woke up in the morning to take a look and whala :hs:
Old Feb 12, 2005 | 08:29 PM
nin97's Avatar
and yes i know that stop bolts arent needed for t56s...apparently they have internal stops? either way...i pulled them out more than enough
Old Feb 14, 2005 | 08:47 PM
Eff's Avatar
Eff
Interesting. How exactly would a bad syncro cause it to pop out of gear?
Old Feb 16, 2005 | 05:53 PM
nin97's Avatar
well basically the gears wouldn't be lined up (or something like that) when you let off the clutch which in return would cause it to go pop
OldSchoolSS
Feb 18, 2004 10:32 AM
ZDriver96
Jan 22, 2004 04:48 PM
greg0101
Jun 26, 2003 08:47 PM
Ponyhntr
Advanced Tech
10
Nov 19, 2002 11:35 AM
