? about t56 swap
Old Feb 5, 2005 | 11:47 AM
DeezT/A's Avatar
? about t56 swap
when i do my t56 swap in my 95 t/a will my stock wireing harness have all of the conectors that i will need? also what do i do with the extra conectors?
thanks Dustin
Old Feb 5, 2005 | 02:01 PM
SSmoked's Avatar
Re: ? about t56 swap
None of the connectors will work. You will haveto buy a VSS pigtail from the dealer which cost me like $30 and splice it into the old one if you want your speedo to work. Then just get your computer tuned and the automatic deleted from the PCM and your good to go. Just zip tie all the old connectors out of the way so they dont drag on the road like mine did.
Old Feb 5, 2005 | 04:06 PM
GreenDemon's Avatar
If you're cheap like me you can just solder the wires right onto the sensor and put some epoxy in there. No problems yet. I added some extra wire for dropping the tranny.
Bxlt1
Sep 29, 2015 03:18 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
