Installing new gears
Old Feb 4, 2005 | 08:01 PM
1997Z's Avatar
I am having a set of Richmond 3.73's installed in my 2 series carrier. I am also having the Richmond Mega kit installed. I have a SuperChips tuner to set the gear ratio.
Does anyone have any advice about or experience with this setup? Besides increased acceleration and higher RPMs on the highway, what else can I expect to change? Should I be installing any thing else to compliment this change?
Thanks...
Old Feb 5, 2005 | 12:50 AM
WestCoast96Z28's Avatar
Re: Installing new gears
A higher stall (2800-3000) torque converter is a good compliment to lower gears.
Old Feb 5, 2005 | 04:53 AM
Z28Nut's Avatar
For the actual gear instal put in a solid pinion spacer instead of the crush collar. A stud girdle rear cover (cast cover with studs that preload bearing caps & built in drain plug) will help beef up the 10-bolt, too.
I went from 2.73 to 3.73 and had a 800rpm increase in highway cruise rpm. 1800rpm @ 70mph to ~2600 rpm. Made vthe car so much more fun to launch and drive
You might want some stickier tires.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
97SSdude
Dec 31, 2014 07:43 PM
Noenav
Dec 6, 2014 07:35 PM
Jul 4, 2005 05:00 PM
