1994 v6 to carb
Old Jan 31, 2005 | 07:59 PM
StrokinIt383's Avatar
1994 v6 to carb
I recently purchased a 94 v6 camaro. I have a built 383 that i would like to put in it. What would i have to do? New k member? MEch fuel pump and sump? What about the wiring...would i have to use some custom mechanical gages? Anything else i should know? How would i hook the starter up, etc. I also have a 89 built 700r4 that i would like to retrofit. What would i have to do with this? This was all going to go into my 89 RS but i have this car and changed my mind. Any help is appreciated.
Old Feb 1, 2005 | 12:26 PM
stale's Avatar
Re: 1994 v6 to carb
Swapping a V8 into a V6 4th gen is one of the more difficult projects to take on. Do a search in the V6 forums, you'll turn up a bunch of disheartening results.
Old Feb 1, 2005 | 06:19 PM
Crovax WS-6's Avatar
Re: 1994 v6 to carb
doing that is gonna be a TON of work. I dunno about the K-member, but i do know you have to cut a hole in the cowling to fit any kinda air cleaner. and forget puttin any kinda highrise intake on it. itll never fit and as itll be sittin you will need a cowl hood to get any type of air into the carb.
Old Feb 1, 2005 | 06:27 PM
Erik's Avatar
Classic Tech Moderator
Re: 1994 v6 to carb
This should probably go in the V6 forum, so I'll move it there for ya.
PopoFormula
Oct 12, 2015 04:19 PM
Kawi
Sep 28, 2015 09:01 AM
Formula Steve
Sep 19, 2015 08:48 PM
scottcba1
Sep 8, 2015 09:52 AM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
