Can I Go 200?
Old Jan 31, 2005 | 07:30 PM
EVERESTZ28's Avatar
Can I Go 200?
I'm runing 150 and want more, but my engine is stock, NX sayed that maybe i can go 175, but not 200, do you know some one runing more than 175 with no forged pistons?
Old Jan 31, 2005 | 08:45 PM
RacinLT1's Avatar
Re: Can I Go 200?
i ran 175 with a stock LT1. could of pushed it more,but the trans let go.
200 is very touchy ground,you have to be absolutely SURE the fuel system is top notch and has a very good pump. also ignition and timing and tuning will be extremely important.
Old Jan 31, 2005 | 10:26 PM
LT4383's Avatar
Re: Can I Go 200?
I ran a 200 shot through a single shark nozzle several passes. My fuel system was upgraded, timing pulled, highier octane fuel....It worked, but my tranny went out as well, soon after.
Old Feb 1, 2005 | 09:17 AM
Frans96SS's Avatar
Re: Can I Go 200?
i ran a 175 for a while and have a 200 on it now ... but ice only had time to make a few passes i think the limiting factor on the 200 is the -4an line
Old Feb 1, 2005 | 11:06 AM
MEAN_SBC's Avatar
Re: Can I Go 200?
Actually, the limiting factor on the shark nozzle is the 3an lines going to the nozzle. I believe they will support up to 250.
I've run that size shot on a stock engine before and I didn't have a problem. The fuel system was not stock, the plugs were cold, and the ignition was retarded accordingly. But, with that size shot on a stock engine, there is always a chance that something could let go. You just have to weigh the benefits of the gained performance, against the consequences that could arise if something lets go.
Old Feb 3, 2005 | 12:59 AM
BlueCamaroZ28's Avatar
Re: Can I Go 200?
What size are the Jets for 200 and 250HP,Nitrous and Fuel Jets?.
G-BODYT56
Jan 14, 2022 11:14 PM
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CARiD
Sep 7, 2015 08:21 AM
