should i have a on/off switch for alk/water injection?
Old Jan 29, 2005 | 04:31 PM
flusz28's Avatar
for my alk/water injection kit should i buy a on/off switch for the setup? or is it okay to just have it on all the time?? would that hurt anything?? what is the best for a LT1 with a s-trim blower- all water or a meth/water setup?
Old Jan 30, 2005 | 08:46 AM
Kraest's Avatar
Retired
Re: should i have a on/off switch for alk/water injection?
Are you pushing the envelope enough to where you need alcohol/water injection?
You aren't at the stock compression with that S-trim, huh?
Mike
Old Jan 30, 2005 | 04:58 PM
flusz28's Avatar
mike i have the blower pushing 8 psi for the moment and have head work and other things done. but i figureed out my own question talking to a vendor.
Old Jan 31, 2005 | 10:11 AM
Kraest's Avatar
Retired
Stock bottom end? 10.5:1?
If so, you'll definetly want to consider alcohol injection to help keep detonation to a minimum and/or possibly even run a couple gallons of race gas.
Mike
Old Jan 31, 2005 | 10:33 AM
flusz28's Avatar
stock bottom end for now- i rarely ever drive the car and never take it to the track. so the motor will hold up for along time.
Old Jan 31, 2005 | 10:38 AM
Kraest's Avatar
Retired
Yeah, I'd definetly consider water/alcohol injection with the compression that high.
Not a good idea, especially at 8 psi.
Mike
Old Jan 31, 2005 | 10:42 AM
flusz28's Avatar
not sure what my compression is.. but the car is just a toy. i have fun just letting it sit covered up safe in my garage. so when its time for a rebuild oh well its time then. things don't last for ever.
Old Jan 31, 2005 | 10:45 AM
Kraest's Avatar
Retired
Well, assuming the combustion chambers weren't opened up extensively during porting and the head gaskets remained stock height, you're at about 10.5:1, which is extremely high for a forced induction motor.
Mike
Old Jan 31, 2005 | 10:51 AM
flusz28's Avatar
using felpro 1074's
Old Jan 31, 2005 | 11:53 AM
Kraest's Avatar
Retired
That's just a replacement gasket for the LT1, which means that it remains at stock compression. You should have discussed this with a professional LT1 engine builder before you tried to stick 8psi through a stock-internal LT1 with stock compression.
Good luck
Mike
IndyZman
Oct 22, 2015 02:17 PM
drt
Sep 27, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
