Idle + Running Problems
Old Jan 27, 2005 | 07:15 PM
Thacker's Avatar
Car cranks and wants to idle if we hold it around 1k rpms.. and then slowly let it down. If we just crank it it'll idle for a second then immediately die. Took it down the road twice and it'll miss at low rpms.. then clear up once we give it some gas. However if we let it come back down to idle it'll surge once or twice and then die.
Car is also hard to start at times, and will onyl start if given some throttle.
IAC has been replaced.. coolant temp sensor has been replaced.. and the vacuum leaks have been fixed. Hole has been drilled in the TB decently large.. and the idle screw has been adjusted to let more air in.
Any help is once again appreciated.
UPDATE. Car will not idle at all without the idle position screwo n the TB turned almost all the way open. The car will crank, and immediately die. Immediately.. cam will hit twice or three times and then die.
Old Jan 28, 2005 | 10:42 AM
dcrews's Avatar
Re: Idle + Running Problems
vacuum leak?
Old Jan 28, 2005 | 10:44 AM
Thacker's Avatar
Originally Posted by dcrews
vacuum leak?
Vacuum leak would cause it to die immediately?
Before when I had a vacuum leak it would rev up to 3k immediately and hold.. that was my last problem we fixed.
Old Jan 29, 2005 | 02:34 PM
ATI - T/A's Avatar
Is the car tuned or are you on stock tune
Old Jan 30, 2005 | 10:54 PM
Thacker's Avatar
Mail order tune.. by Alan @ Futral Motorsports.
Old Feb 9, 2005 | 06:54 PM
SIKBIRD's Avatar
CHECK UR FUSES
Alex Barnes
Jan 24, 2015 10:21 PM
edman
Jan 22, 2015 02:45 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
jayblev95
Dec 1, 2014 06:55 AM
slothgrant
Aug 22, 2002 03:01 PM
