Gauges are bouncing all over the place
Old Jan 27, 2005 | 04:29 PM
Beyonce Knowles's Avatar
For some reason my speedometer and tach have started bouncing around for no apparent reason. I can't feel or hear any difference in how the engine is running when it happens. The speedo will sudenly drop or gain like 7 mph almost instantly, then bounce back Same w. the tach. I couldn't tell if they both happeded at the same time. My volteage meter was also fluctuating. Think it might be sudden drops/surges in voltage? Any ideas? Oh, I had my gauges out this weekend, but it didn't start until today (3 days and ~200 miles ) Any thoughts? Loose connection?
Old Jan 27, 2005 | 04:54 PM
Don't Look Back's Avatar
Re: Gauges are bouncing all over the place
Since you said you had the gages out I'd check for loose connections like you said. However, my gages acted the same way when my igntion switch went out.
Old Jan 27, 2005 | 05:14 PM
99andMine's Avatar
I havent had my guages out but my voltage meter likes to go up and down. The only difference...my lights go with it!! Kinda like a standard when youre about to kill it but when its sitting at idle or when coming to a stop. I had my battery and my alternator checked and theyre operating properly, any ideas??
Old Jan 28, 2005 | 05:45 PM
AZLS1's Avatar
Check all of the grounds.
Old Jan 29, 2005 | 04:03 PM
RedRyder518's Avatar
Sounds stupid but in my friends Trans Am, whenever he got on the gas or hit a bump, his gauges would all go haywire. He later found out it was the battery was loose and the positive terminal was making contact with the air conditioner. You can tell if it is by checking if the battery is loose and if there is a bunch of carbon on it where it was arching.
Old Jan 29, 2005 | 10:44 PM
99andMine's Avatar
Never thought about it arching before...theres about a 3-4 inch space there though and everything is tight. But now i have something coming loose under my dash pad...if its not one thing its another!
Red Hawk 94
Mar 18, 2019 04:03 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
mattstrike
Mar 11, 2015 07:33 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
jj71787
Jan 31, 2015 10:20 PM
