96 lt1 with a4 :help removing shift handle
Old Jan 23, 2005 | 06:00 PM
SMOKINGV6's Avatar
how do you remove the handle to get the plastic console out? someone must know? i didnt see a clip once i removed the square button!
Old Jan 23, 2005 | 06:24 PM
2cub49's Avatar
Re: 96 lt1 with a4 :help removing shift handle
There's a staple like clip about half way down the front of the handle.
Just pry it loose with a small flat screwdriver.
It just presses in to reinstall it.
Old Jan 23, 2005 | 06:43 PM
Pry out this clip, then pull up on the ****. It may feel stuck and come loose unexpectedly. Don't hit yourself in the face.
Old Jan 23, 2005 | 07:34 PM
SMOKINGV6's Avatar
thanks, il try that now
Old Jan 23, 2005 | 10:57 PM
hotrod18_69's Avatar
Yes because it hurts. ALOT!
Old Jan 23, 2005 | 10:59 PM
SMOKINGV6's Avatar
I got it out, thanks a bunch guys!
Old Jan 24, 2005 | 12:22 AM
Even when you are not removing the shfter ****, you should not hit yourself in the face.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
97SSdude
Dec 31, 2014 07:43 PM
