500+ hp 6speeds.
Old Jan 20, 2005 | 09:22 PM
my94blackz's Avatar
500+ hp 6speeds.
What rear gear are you running? What is your 60 ft? 8th? 1/4? plus whats your compression ratio?
Old Jan 20, 2005 | 09:51 PM
atljar's Avatar
Re: 500+ hp 6speeds.
BUddies car, 48x rwhp through 9 inch/28" slicks
4.30gears / 10.76 @ 130+ / 1.5x 60fts / 11.5cr
I should be there too this year, but havent had the car to the track yet, just finished her up.
Old Jan 20, 2005 | 09:55 PM
firetird's Avatar
130+ with 48X rwhp! how much does that car weigh?
Old Jan 20, 2005 | 10:40 PM
atljar's Avatar
It consistently trapped high 127-128, ran 131.XX on its best day which was VERY negative DA (-1800?). I believe raceweight was about 3700.
It was actually 12:1 CR, sorry. 487 rwhp to be exact, on the engine dyno it made 587HP @ 6900 / 485TQ @ 4800 but the cams advance was mechanically altered after the engine dyno session.
396 12:1 comp. LT1
Billet angle 4 bolt splayed caps
Cola (3.875 stroke) lightweight drilled forged crank
6" Eagle H-beam rods
Forged Ross nitrous pistons
Canton Oil Pan
Solid Roller 248 / 256
Cloyes "true double roller" timing chain/electric water pump
hardened pushrods/guideplates
AFR 220 CNC FULLY PORTED w/ 30 hrs of hand porting (2.08/1.60 valves) FLOW 330 CFM!!!!!
triple 1.57 valve springs w/ titanium retainer
Same car is now heads/cam ls1 stock bottom end. Dropped few hundreds of lbs in race weight though.
10.92 @ 126.29 1.5960' 447RWHP N/A
Old Jan 21, 2005 | 12:32 PM
camz383's Avatar
I'm running 4.10s on a stock rear, which just blew on the time in my sig, with a 1.67 60'
karpetcm
Feb 9, 2015 09:21 PM
bossco
Nov 29, 2014 10:18 AM
Z28LT1_Just_Nasty
Sep 19, 2007 01:57 PM
stereomandan
13
Jul 25, 2006 05:44 PM
JS02
May 5, 2006 11:22 AM
