Rear Sway bar question
Old Jan 20, 2005 | 07:35 PM
ZyberMunster's Avatar
Can anyone tell me if a 82-92 Camaro IROC 34MM Sway bar will work on my 1994 Z28??
Any mods needed??
Laterzzz...
Old Jan 20, 2005 | 08:51 PM
PJS TOY's Avatar
Re: Rear Sway bar question
Try posting this in the Autocross section. I bet some one there knows.
Good Hunting,
PJ
Old Jan 20, 2005 | 10:52 PM
teke184's Avatar
what freakin IROC came with a 34mm REAR bar???
i've heard the rear bars are interchangeable since it is basically the same suspension setup.
the front however is totatlly different...won't work
Old Jan 21, 2005 | 01:13 AM
speed fiend's Avatar
Even if it does fit, I don't think you would want to run such a huge rear bar. You're going to get some crazy oversteer.
Old Jan 21, 2005 | 01:36 AM
I made a big boo-boo!!!! It's a 24mm NOT a 34mm bar.
Thanks Teke!!
Laterzzz...
Old Jan 21, 2005 | 06:24 AM
teke184's Avatar
i'm pretty sure it will fit no problem.
buy some poly end links and bushings and you'll be all set.
however not having an upgraded front piece will probably negatively affect your handling as stated above.
Old Jan 21, 2005 | 09:30 AM
I've got 1LE shocks/springs/front swaybar/19mm rear swaybar. All ES bushings front/back. SFCs/APHR/STB/LCAs and a Spohn TQ still I am not happy with the rear of the car rolling a bit too much for my taste. It doesn't break loose but I would like a bit more tightness in the rear, also running 11in rear wheels with 315s.
I originally was looking for a 21mm bar but they are kinda scarce or very $$$$!!
Open to suggestions, thanks all!!
Laterzzz...
Old Jan 21, 2005 | 10:44 AM
teke184's Avatar
does suspension techniques make a 35mm solid front bar for the 3rd gens?
that combined with a 24mm rear should REALLY flatten the car out.
either that or some better shocks...bilstein HDs or something like that
Old Jan 21, 2005 | 11:17 AM
unvc92camarors's Avatar
3rd gens stock came with some big bars
i think 32/21 was base
so 35 wouldnt really make THAT big of a difference, although it'd definately help
Old Jan 21, 2005 | 11:31 AM
I already have ther 35mm front bar hopefully the 24mm rear bar will "flatten" out the car.
Laterzzz...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
