i have a little too much oil in my car, think itll do anything?
Old Jan 20, 2005 | 06:31 PM
Donohue96M6Z28's Avatar
it seems like its a half-3/4s of a quart too full, think it will hurt anything?
Old Jan 20, 2005 | 06:45 PM
BadCo.'s Avatar
Re: i have a little too much oil in my car, think itll do anything?
too much oil will cause the oil to froth into a "foam" as the crank churns it and then the oil pump cannot pump foam...I would drain it out to the proper level but that's just me.
Old Jan 20, 2005 | 06:57 PM
sounds like a plan, ill just get my oil changed tomorrow, thanks man
Old Jan 20, 2005 | 07:01 PM
Beyonce Knowles's Avatar
Get it changed? Come on man, it's time you learn to change your own oil!
Old Jan 20, 2005 | 07:04 PM
haha i know how to change it, im at school tho, no tools/anything, plus walmart does it pracitcally for free minus the oil, the labor is close to nothing
Old Jan 20, 2005 | 11:11 PM
crasher88's Avatar
and if you have too much oil it can get into the combustion chamber and get shoot into the cat and seriusly mess up your cat.
Old Jan 21, 2005 | 01:57 PM
anasazi's Avatar
wal-mart oil change?
i think your better off leaving the slight amount still in there ...
Old Jan 21, 2005 | 02:22 PM
IRONFIST's Avatar
Wouldn't it be easier to drain some out... ?
Old Jan 21, 2005 | 02:32 PM
89305rs's Avatar
why dont you cust CRACK open the drain plug, let a little drizzle out and check it until it gets to the point where its where you want it?
Old Jan 21, 2005 | 07:47 PM
Birdman7389's Avatar
What? I think your confused somehow? There is not really a way for extra oil to get into the combustion chamber, at least not from having too much oil in the engine......
Old Jan 22, 2005 | 01:50 AM
Z95m6's Avatar
I think 3/4 of a quart to much maybe pushing it. I usually run an extra 1/2 qt in mine. The last thing i want is to be reving 6k + and have it pump the pan dry.
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
