4.10's worth it in an A4???
Old Jan 20, 2005 | 10:15 AM
DB75's Avatar
I'm looking to buy a 12 bolt and stay with the 3.73's. My friend suggests I try the 4.10's. Would the 4.10's and my 2800 stall be that much more of an improvement over the 3.73's? Also, with the steeper gear can I get away with a 26" tire or do I need to step it up to a 28" tire? I want to buy the M/T drag radials for my salad shooters but before I do I want to make sure which tire size will work better with the 4.10's. Any advice you guys can give is appreciated.
Old Jan 20, 2005 | 11:02 AM
1BAD86Z's Avatar
Re: 4.10's worth it in an A4???
It all depends on the combination you plan on running. I looked at your mods and see you are running all motor, but if you plan on running a power adder then keep it around 3.90 - 3.73 with a 28' tire. Also you did not say if you drive it around the street much.
Old Jan 20, 2005 | 11:26 AM
DB75's Avatar
I use my car primarily for the track now (no longer my daily driver). I plan to keep the car N/A (cam, rr's, maybe heads). I run 13.0's @105 mph on 1.8 60 fts. Just wondering if the 4.10's are the way to go.
Old Jan 20, 2005 | 11:41 AM
unvc92camarors's Avatar
well, it also depends on what cam you want to get
if it mainly likes to operate in higher rpm ranges, those gears could keep it better in the powerband and help on the launch
then again, it could just make your job of launching all that more difficult
Old Jan 20, 2005 | 04:54 PM
Antz97ZNJ's Avatar
Should be fine for a track car
Old Jan 20, 2005 | 05:16 PM
12SCNDZ's Avatar
I ran 4.10's behind a bone stock LT1/all motor '93 Z. The car ran 12.82. After doing my head/cam combo, I was on my shift lite about 75 ft. before the stripe, and I was making a 3-4 shift in the 1/4. The car went 12.0 like that. Last winter, I swapped in a set of 3.73's without doing anything else, and the car slowed down to a 12.2. I went to 3.73's with the intent of running nitrous, though.
Frank
Old Jan 20, 2005 | 06:05 PM
Capn Pete's Avatar
Depending on how far you take your car, the 4.10's should work fine for you. As you increase power, and increase your trap speed, you'll start running out of gear in 4th. BUT, as you increase power, chances are you'll also increase the rev capability of your motor, so you can still run higher trap speeds. If you get limited again, you can always run 27" or 28" tires, and get more trap speed capability again.
For a good street/strip car, I think the 4.10's are just about perfect.
Old Jan 20, 2005 | 08:54 PM
Spinner's Avatar
4.10s are good to 124 in the 1/4 mile. Keep it under that and you'll be fine if you can stomach the extra highway rpms.
Old Jan 21, 2005 | 07:39 AM
DB75's Avatar
Thanks for the replies guys. I think I'll give the 4.10's a shot.
blaze309
Sep 8, 2015 05:27 PM
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
whitehooptie
Aug 17, 2015 08:35 AM
