Eibach Pro-kit
Old Oct 8, 2002 | 07:10 PM
99SS89RS's Avatar
Question Eibach Pro-kit
I just had a question about the eibach pro-kit or any lowering spring kit. Would I have to change any suspension parts(con. arms, panhard bar,etc.) when lowering my car (99ss) with the pro-kit or will it be fine just swaping in the springs? Any help is appreciated. Thanks.
Old Oct 8, 2002 | 07:31 PM
Dark Angel's Avatar
You will probably need Lower control arm relocation brackets on the rear to keep the LCA's horizontal with the ground. Then you will need a front end alignment. Most people haven't needed an adjustable Panhard rod to recenter the rear unless you are running wider tires, but it's an option.
KYWes
Aug 10, 2015 07:03 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
93zder
Jul 26, 2002 10:10 AM
Cricket92RS
Jul 12, 2002 07:59 PM
CivicDestroyer
Jun 23, 2002 10:18 PM
