3.4L engine replacement problem
Old Jan 15, 2005 | 09:29 AM
blackcar628's Avatar
I have a 95 camaro that i put a 94 motor in. when you try and crank the motor it turns over then it will backfire up through the intake i know the timing has not been messed with because the motor was running when pulled about 6 months ago.
Old Jan 15, 2005 | 08:14 PM
6SpdLT1Z's Avatar
Re: 3.4L engine replacement problem
Crank Position Sensor?
Old Jan 20, 2005 | 11:18 AM
viper98885's Avatar
Definitely has something to do with the ignition system. I had a bad coil one time and it did the same after cranking it for a little while. Make sure all wires are on the right coils and right plugs.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jazsun
Dec 29, 2014 12:14 PM
Zomie
Sep 2, 2002 09:04 PM
