10 bolt series 2 and 3 carrier difference
Old Jan 11, 2005 | 08:22 PM
joshp007's Avatar
How do you tell the difference between the two?
Old Jan 11, 2005 | 08:25 PM
87DJP2001's Avatar
Re: 10 bolt series 2 and 3 carrier difference
How about using the gear ratio for identifcation. I don't think there are visual differences between a 2 & 3 series carrier.
Old Jan 11, 2005 | 08:55 PM
Capn Pete's Avatar
Unless you had them side by side, you'd never know the difference. You can't even "see" it until you stand them on end and measure the distance to the face where the ring gear bolts on.....it's 1/4" either "left" or "right" to accommodate normally larger or normally smaller pinion gears.
How to tell? Well, if the carrier has factory 2.73's --> 3.08's, then it's a 2-series. If it has 3.23's --> 3.42's, then it's a 3-series. However, 3-series ratios can be bought to fit onto 2-series carriers.....difference being the ring gear is 1/4" thicker.
Old Jan 12, 2005 | 01:03 AM
Pro Built Automatics's Avatar
2.41's & 2.56's use the 2 series, all others use the 3 series on 8.5" ring & pinions. What are you wanting to do?
Old Jan 12, 2005 | 01:28 PM
94Zpower's Avatar
Visually the ring gear is a fair bit thicker on the 3 series carrier gear for a 2 series carrier.
Old Jan 12, 2005 | 02:39 PM
87DJP2001's Avatar
May be true, but unless you know the thickness ("fair bit thicker") is not a very good discription.
Old Jan 12, 2005 | 02:52 PM
94Zpower's Avatar
Have you ever looked at the 2?? I have and there is a noticable difference, sorry I cant measure it to tell you exactly because I am at work.
Old Jan 12, 2005 | 03:38 PM
87DJP2001's Avatar
Tell that to the guy who asked the question and explain your little bit bigger if he he hasn't seen the two
before. You sounf like the farmer who said its a hoot and holler over the next hill.
Old Jan 12, 2005 | 09:22 PM
Capn Pete's Avatar
When I had a 2-series and a 3-series carrier side-by-side and I measured, the difference is 1/4" (location of the face where the ring gear bolts to...hence, the 2-series ring gear would be 1/4" thicker for a 3-series ratio). A 1/4" is visible to the naked eye.
Old Jan 13, 2005 | 06:51 AM
87DJP2001's Avatar
I agree, but what would the dimension be if the rear was in the car??? What is the 1/4" number compared to???
Example: I check the thickness and its and its 1.175 is this number 1/4 small or larger to a 2 or 3 series carrier ????
Old Jan 13, 2005 | 08:00 PM
Capn Pete's Avatar
What I'm talking about is having the two carriers side-by-side, on a flat bench, standing on one of the bearings (they've gotta be standing on the same side). If you measure from the bench to the face of the carrier where the ring gear bolts on to, that face will be 1/4" offset depending on which carrier you've got. If they're installed in the car, looking from the back, a 2-series carrier's gear face would be 1/4" *left* compared to a 3-series carrier's.
...does that make sense?
Old Jan 13, 2005 | 08:27 PM
87DJP2001's Avatar
No... not when the diff is in the car and you cant compare it to another one. As I posted a reply to the original question, use the gear ratio stamped on the dr gear for 2 or 3 series carrier. I was just curious to see what people would reply and did get some replies. The gem was "a fair bit thicker".
The End
Old Jan 14, 2005 | 01:52 PM
95Z28Camaroman's Avatar
I know you guys have it sorted but I found this breakers yard that explains it pretty good with pictures too, here is the link:
http://www.tacreationsusa.com/differential_carriers.htm
Victor Lamb
Aug 26, 2017 02:52 PM
BigWil
Mar 29, 2015 12:24 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
InfernalVortex
Jan 17, 2015 09:35 AM
