Check Engine Light/ Gas tank pressure???
Old Jan 5, 2005 | 08:07 PM
SSHORTT's Avatar
My check engine light has been on, sometimes it will go off and then back on! I took it to Auto Zone and the guy said the code showed low pressure in the gas tank and that the only thing he knew to do was change the gas cap, After i did that the light has been on! (a Week).. So what else could it be? And if any what performance loss is this causing!
Old Jan 6, 2005 | 09:05 AM
Greed4Speed's Avatar
Re: Check Engine Light/ Gas tank pressure???
Do you mean SES light? This is just emissions stuff.
If your gas cap isn't on tight enough it'll trip the SES light. I think it take a certain number of start ups to get it to reset, or you could have reset yourself.
Old Jan 8, 2005 | 12:48 PM
Team ZR1's Avatar
You need to post what the DTC codes are for the guy may be wrong in what the DTC means.
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
blac94Z
Nov 24, 2014 07:12 PM
