An amp running off my stock Monsoon Head Unit??
Old Jan 5, 2005 | 09:55 AM
gamecockfan04's Avatar
I am considering a small 4 channel amp to run my 4ohm door speakers and possibly my old 5 1/4 (4ohm aftermarket) door speakers that I put in the hatch area, or should I run the sail panel 6 1/2 woofers? Whats the best setup to run off the 4 channel amp if its even a good Idea.
Also my car was not a Monsoon system car, but I bought a Monsoon Head Unit out of a 02' TA and put it in my 95' TA.
Old Jan 5, 2005 | 05:27 PM
firebirdude's Avatar
Re: An amp running off my stock Monsoon Head Unit??
I really recommend against using an aftermarket amp on the stock speakers....
Old Jan 5, 2005 | 08:06 PM
They're aftermarket speakers. The 6 1/2"s in the door are Alpine's and Im moving the Kenwood 5 1/4" speakers that were in the doors to the hatch area, so the only thing stock are the 6 1/2" subs in the backseat sail panels and the tweeters.
Old Jan 5, 2005 | 08:18 PM
I'd run the front doors and rear subs off the amp. The 5 1/4"s off the headunit..... actually I wouldn't even put them in there....
And yes, you can connect your amp to the stock headunit. Using any line output converter.
Brian-94TA
Jul 31, 2002 02:52 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
CobraEatr
Jul 29, 2002 11:46 AM
97QuasarBlue3.8
Jul 22, 2002 09:09 AM
Rino1313
Jul 19, 2002 04:31 PM
