wheres the fuel filter on our cars
Old Jan 2, 2005 | 08:48 PM
bad84z's Avatar
Don't have a manual handy, I have a 96 3.8 and was wondering if anyone knows off hand where the fuel filter is. Got 70,000 on the car and I figure it could use changing. Thanks in advance Jason
Old Jan 2, 2005 | 09:10 PM
Camabird's Avatar
Re: wheres the fuel filter on our cars
Get under the car and look on the drivers side right infront of the rear tire. You'll see some fuel lines and a little cylinder thinger (the fuel filter). Shouldn't take more than 5 minutes to change, be sure to relieve the pressure in the gas lines and look out for the gas, it will drip all over.
Old Jan 2, 2005 | 09:15 PM
bad84z's Avatar
Thanks alot, I am guessing by relieving the pressure, you just take the gas cap off right. Thanks again
Old Jan 2, 2005 | 11:14 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
there is also a little valve on the fuel rail that is used for testing fuel pressure that can be used for relieving the pressure, i personally did both when i did my filter
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
30thZ4C
Dec 26, 2014 05:09 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
