3.73 opinions
Old Dec 22, 2004 | 10:22 PM
camzaro28's Avatar
3.73 opinions
i have done a lil searching but i would like some more input! i am hearinf conflicting stories about gears. i have 3.23's now and i have been thinking about jumping up to 3.73's. and eventually a 3500 yank or similar.
my ? is will those gears help improve my times, and trap speed at the track?
some are telling me that they will do no good, just looking looking for more input from guys that have went from 3.23 to 3.73!
thanks
Old Dec 23, 2004 | 01:58 AM
GreenDemon's Avatar
Re: 3.73 opinions
A gear swap will definitely improve your times- as long as you have the traction.
And BTW those people that are saying it won't do any good are probably the same ones that blabber about how doing a gear swap on a stock late model GT will drop it into the twelves.
Old Dec 23, 2004 | 08:49 AM
camzaro28's Avatar
Re: 3.73 opinions
thanks man!
anymore?
Old Dec 23, 2004 | 09:31 AM
kostya_f's Avatar
Re: 3.73 opinions
In my opinion gears will only help if you have more traction than power in 1st gear with whatever tires you have.
I have kdw, 3.23s with m6(taller 1st) and whenever the temperature outside is below 40F, on the street, I loose traction as rpms start climbing. This thing only makes 323rwhp too.
Old Dec 23, 2004 | 09:37 AM
93LT1355's Avatar
Re: 3.73 opinions
3.73's improved my times out at the track and I thought they made my car a lot funner to drive on the street too.
Old Dec 23, 2004 | 09:46 AM
camzaro28's Avatar
Re: 3.73 opinions
did u have 3.23' b4? just wondering cuz i know from 2.73 it would be a huge difference!
and by how much did they help ur qtr times?
thanks again
Old Dec 23, 2004 | 01:51 PM
93LT1355's Avatar
Re: 3.73 opinions
I had 3.23's before and it cut .2 off my times, so for you it would probably be closer to cutting .3 off your times
Old Dec 30, 2004 | 12:18 AM
revtime's Avatar
Re: 3.73 opinions
I went from 3.23s to 3.73s and was very glad I did.
with the gears and a shift kit it was like a totally different car.
You will need some suspension mods with the gears, my car just spun all day till I put some suspension and tires on it.
Old Dec 30, 2004 | 09:25 AM
camzaro28's Avatar
Re: 3.73 opinions
that is what i wanted to hear revtime do u have anytrack numbers with b4 and after?
i am already needing suspension as it is now! i am working on it. jsut want it fast now, then work on suspension. when i have the money i am buying whatever is a steal at the moment!
so from what i have gathered i will be geting some 3.73 soon!
93 RedBird
Nov 15, 2015 08:24 AM
Ks0209
Oct 1, 2015 07:32 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
