Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Paging Derty
Old Oct 7, 2002 | 08:33 AM
Grover's Avatar
Paging Derty
Steve,
What is your rev limiter set at? Where are you shifting at and at what RPM do you cross the line at?
I am asking because the 28" tall slicks I was using Saturday were too tall as I was just barely getting into 4th gear before the traps. And on one run I ran 3rd gear out and crossed the line hitting my 7000 rev limiter. My shift light is set at 6800, so I was shifting around there. I think I need to step down to a 26" tall tire or possibly a 27" and was wondering what you thought of the QTP's.
Old Oct 7, 2002 | 09:05 AM
derty's Avatar
I have a 3.73 rear gear. I leave the line at 5500, rev limiter is 6500 shift light comes on at 6200. I shift into 4th at about 1000 feet. I clear the trap at about 4800 or so. I have the car geared for nitrous, so I'll run out of gear eventually .
I believe my Hoosiers are 26.1" tall.
Old Oct 7, 2002 | 12:34 PM
TheNovaMan's Avatar
Hey Chad, did you end up getting rid of that spin-then-bog problem on launch after you painted the stripe on the tire?
Old Oct 11, 2002 | 03:54 PM
Grover's Avatar
The only thing different I did was I did a much shorter burn out and that seemed to help at least it got me to a 1.795 60'.
I will probably switch to a 26" tire for next year, until I use nitrous then I will need a 28" tire.
Old Oct 11, 2002 | 03:59 PM
TheNovaMan's Avatar
At what RPM did you launch?
Old Oct 11, 2002 | 05:19 PM
MichiganSkip's Avatar
Chad, did I just see you use the "N" word? First pass and you'll be another nitrous junkie. Let me know where you are mounting the bottle, I have the trick set up for the wheel well(and cheap too $45 shipped)Need some cashflow for mat'l for the laptop holders. I'm trying to keep them about 60-70 bucks. That aluminum isn't cheap anymore
Skip
Old Oct 11, 2002 | 07:09 PM
Black Sunshine/ 00SS's Avatar
Funny you should mention this. My 26" are too small. I figured out why the ET's were not hooking very well. They were worn a bit
I switched them to the ET drags I got last year and only put 3 runs on. 26" x 10.5 also.
Going to the track tomorrow hopefully. See if I can get itto hook better.
My car shifts into 4th well before I cross the line
I might pick up a bit with the 28".. How much tread you got left on those Chad?
Old Oct 11, 2002 | 08:51 PM
Grover's Avatar
Yep, Skip for next year I plan on getting the car in the 11's NA and then spraying a 125 hp hit going for 10's. I could probably buy the bottle mount and the laptop stand at the same time if you want.
Harold, I will have to measure the depth of the holes. What is the new depth?
Pete,
The last few runs I was dumping the clutch at 5800 RPM
Old Oct 12, 2002 | 05:26 PM
Grover's Avatar
Harold,
I measured the holes in the tread and they vary from 0.139" to 0.150".
I don't know how this compares to the new depth, though.
Fatdog2
Sep 16, 2015 11:04 PM
cmsmith
Aug 27, 2015 06:37 PM
97blackformula
Aug 27, 2015 06:02 PM
WPHIG2
Aug 27, 2015 06:37 AM
cmsmith
Aug 20, 2015 07:57 PM
