1996 camaro keyless entry question
Old Dec 9, 2004 | 10:05 PM
96HOTZ's Avatar
How do I find out if I have keyless entry on my car? I bought the car but it did not come with a remote. I have been looking at buying a remote and getting it programmed if I have the keyless entry system already on my car.
Old Dec 9, 2004 | 10:29 PM
Lt1t56's Avatar
Re: 1996 camaro keyless entry question
On my 95 Z the RPO code sticker in the glove box has code AU0, which is keyless entry, pretty sure it is the same code on your 96 if it is equipped with it.
Old Dec 9, 2004 | 10:33 PM
KPZ-28's Avatar
You could check the RPO code on the driver side door and see if it came with it from the factory, I think it is AU0. You can buy a new transmitter for about $30 and section 2 of the owners manual tells how to program it. I'm sure someone else has a better way like where to look for the remote receiver etc.
Old Dec 10, 2004 | 02:16 AM
96HOTZ's Avatar
Thanks a lot, I will check it out! Do you think the remotes that they sell on eBay will work if I do have the code?
Old Dec 10, 2004 | 10:26 AM
unvc92camarors's Avatar
well, one way to see if the reciever is there
check the passenger kick panel (basically, right before the door, there is a small panel between the door and the underdash vents)
the receiver will be in that area if there is one
Old Dec 10, 2004 | 10:29 AM
Dave89IROC's Avatar
OK, I thought a 96 had the reciever built into the BCM?
Old Dec 10, 2004 | 03:22 PM
RUFST's Avatar
on my 96 w/keyless entry and alarm if you take the cover off back where the spare tire is the alarm sensor is in there...if it has that then you have keyless entry also..
Old Dec 10, 2004 | 06:04 PM
96HOTZ's Avatar
Yes, I have the code AU0 and I also have the little box in the spare tire well that looks like it connects to the security. THANKS!!!
Old Dec 10, 2004 | 08:31 PM
They do.
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
JasonD
Jul 15, 2002 02:17 PM
