will camaro exhaust fit on a trans am
Old Dec 9, 2004 | 08:40 PM
Silverbandit's Avatar
will the stock y pipe off a 00 camaro fit on a 99 trans am and will the sensors all hook up
Old Dec 9, 2004 | 08:50 PM
teke184's Avatar
Re: will camaro exhaust fit on a trans am
they are the same care...engine...trans...frame...rear...
only thing different is the body panels and interior
so YES
Old Dec 9, 2004 | 09:28 PM
SSpdDmon's Avatar
so YES
Car for car it will swap. Year for year, no. I think in 2000 they went to a bolt-up setup unlike on the 99's where the only disconnect on the passenger side of the y-pipe was at the exhaust manifold flange. If you look at the exhaust parts on the SLP website, you can see they separate 98-99 from 00-02.
http://www.slponline.com/view_product.asp?P=31035
Old Dec 10, 2004 | 04:49 AM
AL SS590 M6's Avatar
Moderator
You sir are correct. If you want to put 00-02 exhaust Y-pipe on a 98-99 you need the cast iron manifolds too.
Old Dec 12, 2004 | 04:43 PM
i have the cats and the pipe, the cats are bolted up to the pipe ready for install.. will it not bolt up to the manifolds? im going to try to see what happens any ways. i just dont understand the big diffrence between this one having bolt on cats and the other being welded on?
Old Dec 12, 2004 | 05:36 PM
94m5's Avatar
I believe one design used cast iron manifolds. The other used a tubular manifold design. I'm almost positive it won't work. But it's your car/ Your money and time. Go for it, and let us know if it works.
Old Dec 13, 2004 | 02:55 PM
SSCamaro99_3's Avatar
The passenger side cat was relocated in 2000 or 2001, and the Y-pipes are not interchangeable without ramoving the cat on a 98-99 car.
Old Dec 14, 2004 | 03:29 AM
Moderator
98-99s used tubular exhaust manifolds
00-02s use CAST IRON manifolds
The y-pipes will NOT interchange, it has nothing to do with welded cats or not.
rockync7
Jan 1, 2015 05:10 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Dec 4, 2014 11:56 AM
Sarahrope64
Nov 27, 2014 11:17 AM
BigManJ
Aug 12, 2002 02:47 PM
