need some pro apinons
Old Dec 7, 2004 | 10:17 PM
BeaversTA's Avatar
I have a 93 M6 with a 355ci with forged pistons and stock crank and rods, Ported heads and a xe 230/236 544/556 on a 112lsa.
I'm considering purchasing a Porcharger w/intercooler. I know I would need a new fuel pump and Injectors what else would I need?
How much PSI should I try and run? How hard would it be to get a 93 to run with a cam and boost? Or should I just slap a 150 shot on it and call it a day.
Thanks for the help
Old Dec 8, 2004 | 12:09 AM
Lisa33's Avatar
Re: need some pro apinons
What compression do you have?
Old Dec 8, 2004 | 01:53 AM
5.0THIS's Avatar
I would think your motor could hold 6-8psi fairly well. I would only hope you at least had some upgraded rod bolts on the stock rods. As for the tune, you'd have to have another custom chip burned for the boosted application.
Old Dec 8, 2004 | 06:05 PM
BeaversTA's Avatar
the compression is stock.
Old Dec 9, 2004 | 01:26 AM
Lisa33's Avatar
Agree
If you dont plan to lower youre comp and run more boost i suggest N2O, sure you have to fill the bottle, keep it warm,etc but it should be alot cheaper and i guess it will preforme better times on the track....
Both ways are possible, its all about youre goal and future plans.
Old Dec 9, 2004 | 08:24 PM
BeaversTA's Avatar
My main concern is that the 93 SD ecm will not work well with boost. Has any one boosted a stock 93 SD ecm with out trouble? I would love to blow this motor up and thow a 383 with #25psi in.
Old Dec 9, 2004 | 09:02 PM
BeaversTA's Avatar
Do you guys think I could run like 8-10PSI intercooled with a dyno tune with my set up?
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 9, 2015 03:33 PM
