4th generation wheels???
Old Dec 7, 2004 | 07:36 AM
streetheatz28's Avatar
Question 4th generation wheels???
Will 4th generation camaro wheels fit on a 3rd generation camaro?? i've heard that they would but you have to use wheel spacers is this true??
Old Dec 7, 2004 | 11:02 AM
Re: 4th generation wheels???
The bolt circle is the same, so they will bolt on. Problem is the offset/backspace. The 3rd Gens had a rear axle assembly that is 3" narrower than the 4th Gens, so the wheels typically have a 1.5" smaller backspace on a 3rd Gen, than they do on a 4th Gen. The puts the 4th Gen wheel too deep in the 3rd Gen fenders. To correct this, you would need a 1" to 1.5" bolt-on spacer.
Old Dec 16, 2004 | 07:12 PM
OutsiderIROC-Z's Avatar
Where's a good place to buy these spacers?
Old Dec 17, 2004 | 02:53 PM
nin97's Avatar
just about any tire shop should be able to sell you spacers
Old Jan 26, 2005 | 01:18 PM
Are they required on the front too? I have an '85 IROC that I am putting a set of salad shooters on.
Old Jan 27, 2005 | 03:12 PM
sszcam's Avatar
You can get a full set of spacers from fbodymotorsports.com
Old Jan 27, 2005 | 07:31 PM
Zepher's Avatar
They are required on all 4 corners and you need to use bolt on spacers, not slip on. I don't even think they make 2" slip on spacers, but if they did I would not run those.
Old Jan 27, 2005 | 07:37 PM
redimpss5's Avatar
I found a good set from thunderracing.com. I also am putting salad shooters on to mount race tires
Old Feb 3, 2005 | 10:45 AM
Thanks y'all. I appreciate it.
NewsBot
Apr 9, 2015 07:10 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Jason Short
Jan 19, 2015 06:33 PM
CaRParts102
Dec 6, 2014 08:45 AM
