Looking for a 306/stock heads tune!
Old Dec 5, 2004 | 05:58 PM
TransAmGT's Avatar
I'm putting:
cc306
1.6 RR
ex-612 springs
cloyes timing chain
And everythign else required for the swap in this winter. Now all i need is a tune.
My mods include:
Hooker Shorties
Cut-out/cat back
CAI
LT4
stock 3:42's
stock heads
stock injectors
stock fuel pump and all that good stuff! I found a tune on zeeya's website but it's for aftermarket heads. Does anyone have a tune i can download? Thanks!
Oh yea...it's a 94
Old Dec 7, 2004 | 02:03 PM
TransAmGT's Avatar
Re: Looking for a 306/stock heads tune!
MArcin...anyone???
Old Dec 8, 2004 | 10:01 PM
dmoor88's Avatar
www.madz28.com
Old Dec 8, 2004 | 10:30 PM
Dan K's Avatar
Someone else's tune isn't going to be perfect in your car, I hope you understand that.
So the file that you said you've already found should be good to use as a base file. Then adjust to what your car needs.
Old May 2, 2005 | 03:45 PM
weinerschizel's Avatar
I tried using other peoples files. Didn't work what so ever. Could never find anybody with the exact same or very simliar setup to me. However, what you can do is use the compair feature in tunercat to contrast your current tune with the tunes you find. Works nicely to see which areas you should concentrate on.
Old May 4, 2005 | 12:59 AM
redcamaroz28's Avatar
I just got my tune for my 230/236 cam. I have your same setup minus the cam. You WILL have to adjust the tune to your own car. Like said above, every car is different. I'll pm you the tune tomorrow if you'd like.
Ryan
Old May 4, 2005 | 01:04 AM
BTW, the 612 springs are gonna be pushed close to their limit with the CC306. They are advertised @ .600 max lift, but Combination Motorsports, Thunder Racing, and many others on this board have said that they are good only up to .570 max lift. The CC306 lift is .544/.576. If you haven't bought the springs, look into some 987's (I believe), or was it 986's??? It's too late to remember, but one of those will fit stock heads without machine, just do a search.
Old May 4, 2005 | 05:16 PM
TransAmGT's Avatar
hmm...already got them on my car and they've been fine for 6,000 miles and many many 6500 rpms pulls...btw i got a madz28 tune now and it's wonderful!
InfernalVortex
Jan 17, 2015 09:35 AM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
