Is a BOV open during cruising?
Old Dec 3, 2004 | 02:25 PM
mn_vette's Avatar
From what I've read, a BOV will open up when there is vacuum in the manifold. So does this mean that when you are cruising down the highway the BOV is open equalizing the pressure across the compressor.
Does this mean that you have to be at WOT(zero vacuum or close to it) to make it shut? I've never used one of these devices and I'm trying to figure them out. Thanks.
Old Dec 3, 2004 | 02:36 PM
mn_vette's Avatar
Re: Is a BOV open during cruising?
Please explain the fizix behind that one, if there is only one vacuum line going to it. Does it use the pressure on the valve to help it open as well? Assuming it uses a valve and not a slid...
Old Dec 3, 2004 | 02:39 PM
96TurboTA's Avatar
Well on my TurboXS BOV, the boost pressure pushes open the BOV from the bottom, and the vacuum pulls it from the top. The combination of the two is enough to overcome the spring pressure keeping it closed. Geoff's explanation was better, but he erased it.
Old Dec 3, 2004 | 02:40 PM
Geoff Chadwick's Avatar
edit: It's been said... nevermind...
Old Dec 3, 2004 | 02:46 PM
mn_vette's Avatar
Thanks guys, that explination helps alot.
OutlawPerforman
Oct 30, 2017 05:40 PM
30th Anniv Z28
Aug 1, 2015 10:39 AM
240ssLs3
Jul 13, 2015 05:06 PM
Jul 10, 2015 02:23 PM
colts0455
Jul 8, 2015 12:21 AM
