Recommendations for First Kit for Stock LT1?
Old Nov 27, 2004 | 09:02 PM
sharpe's Avatar
Hello, I'm looking for recommendations to a begginer who's choosing his first nitrous oxide kit for a stock LT1. I guess a 100 shot is about what everyone is reccomending for a safe level.
Here is what I was thinking about getting myself for Christmas since I've been so good:
http://www.thunderracing.com/catalog...d=179&pcid=161
NOS Nitrous System for 1993-1997 LT1 Camaro/Firebird w/ 15 lb bottle for $719.99
Old Nov 28, 2004 | 01:11 PM
SDAKOVIC's Avatar
Re: Recommendations for First Kit for Stock LT1?
Nitrous works 175 wet kit, about $500.00. Easy to install and adjustable.
Old Nov 28, 2004 | 09:56 PM
old93z's Avatar
My recommendation would be a wet kit. I don't like to idea of having to raise the fuel pressure like on the dry NOS kit. One from NX or nitrous works would be my recommendation. Either would be about 200 dollars cheaper as well IMHO either way it's fun stuff, just don't over do it
Old Nov 29, 2004 | 07:53 AM
94Zpower's Avatar
I am on my first N20 kit and its a NOS wet kit (5151) made for TPI cars but works just the same on an LT1, I would definetly go with a wet kit, its just safer.
Old Nov 29, 2004 | 05:53 PM
slp223's Avatar
i think a wet kit is a much better kit for power but for a starter kit a dry kit is much more forgiving with small mistakes. you can make the kit you have a link to much cheaper get a nos part number 5115 it is the same kit only the main line hose is a little shorter and it does not with a fuel pump. other then that the kit is exactly the same. save the money and buy a fuel pump seperately.
Old Nov 30, 2004 | 10:07 PM
Nitro Dave's Avatar
How about a Nitrous Express single fogger nozzle stage 1 system.They have life time warrenty solenoids and yyou can pick one up for about 525.00.
Dave
Old Dec 1, 2004 | 09:40 AM
slp223's Avatar
I think the NX kit is a much better kit over all but dry kit is a much better new to nitrous kit. it is much more forgiving. here are some reason why. 1. say for instance you have a 100 dry vs a 100 wet. the initial hit is smother on a dry. wich make the car easier to control. 2. bottle pressure is much less important on a dry kit. if you only have 800 psi in a dry kit it will just make less power on a wet kit the car goes lean. 3. if you run the bottle empty with a dry kit nothing happens if you run a bottle empty with a wet kit it just dumps fuel in. it just lets you make a few more mistakes. hence a good starter kit.
Old Dec 1, 2004 | 10:49 PM
Bersaglieri's Avatar
Those are a alot of great things to consider that I never knew or thought of. Thanks slp223. Anything else to consider? What about add-on's necessary for ech kit? And initial cost?
-Dustin-
Old Dec 1, 2004 | 11:39 PM
Bad AZz Z28's Avatar
Zex Dry kit with the 255 walbro inline pump is a great starter kit as well. It plus a window switch and your first bottle fill is under $750, leaves plenty of room for a bottle heater, pressure guage, etc that you may want. It is a simple install. And it matches the fuel pressure increase to the bottle pressure, so even if you arent hitting all out, you are hitting as much as your bottle can. A wet kit in that condition of lower pressure would run rich and bog.
Ive managed mid 120 traps on a Zex dry kit with only a ~150 shot, stock heads, hotcam, shorty headers, no bottle heater. Its a potent little kit in the right hands.
Old Dec 2, 2004 | 03:09 AM
jnjspdshop's Avatar
to the ZEX dry kit
Old Dec 2, 2004 | 09:05 AM
slp223's Avatar
A nitorus pressure guage is the most important extra i you dont know pressure is in the bottle you really have no idea what is going on. A bottle heater helps out quite a bit but you can get away with out one a blow dryer works and so does the heater in the car just kind of a pain in the *** to have to do it that way.
Old Dec 2, 2004 | 04:26 PM
yes a pressure guage is basically a must with a wet kit, as is some way to heat your bottle. I dont have a pressure guage with my dry kit though, as it is not as important. A bottle heater would be nice too, but the bucket o warm water has gotten the job done this far. I'll get around to it one of these days, but its my spare car so it doesnt get as much $$ lovin
I'll be finishing J&J Speed Shop's web site soon, maybe then as a new store special we'll become a paid advertiser and run a group buy, since I know he has NX and Zex deals
Old Dec 2, 2004 | 04:38 PM
IRONFIST's Avatar
Most of the basic kits by Zex, NOS, and NX are good, and you're running such a small shot that a wet kit probably isn't needed... but personally I'd go with a wet kit anyways. Just for that added bit of security I guess. The Zex kit I got was very easy to setup.. as was the remote bottle opener for it.
Old Dec 2, 2004 | 04:43 PM
mattybz28's Avatar
-Dustin-
make sure you arn't running plat plugs. If you're gonna spray much it would be a good idea to get colder plugs.. ngk tr6 are the usual.. could get autolites too though.. just 1 step colder. Also a switch console... very clean and it's stock looking. The switch provided in my NX kit is ugly and you need more than 1 anyways for heater & purge.
Old Dec 3, 2004 | 09:02 AM
Nitro Dave's Avatar
I agree the ZEX and TNT kit is also a good kit.The Zex kit is a good beginner kit.However if you plan on spraying more latter why not just go ahead and buy a system that will flow for 35 hp to 150 out of the box.Then in the future all you need is the extra jets and the system will flow up to 250 hp.It sure beats having to make an investment twice.Plus the NX kits have lifetime warrenty solenoids.
Dave
