How do I take tranny down to get to clutch fork?
Old Nov 24, 2004 | 08:49 PM
Kurt Crosbie's Avatar
What's the easiest way to get it down just so I can tighten down the bolt for the clutch fork?
Old Nov 24, 2004 | 11:10 PM
zx1216's Avatar
Re: How do I take tranny down to get to clutch fork?
So whats the problem exactly? The clutch fork is making noise? Anyway your prolly gonna need to drop it to get to the bolt so you need to unbolt the torque arm and driveshaft. Then unbolt the bell housing, this is gonna be a pain in the *** to get to the top bolts, you will need about 3 feet of etensions ans a swivel joint. After you get it unbolted it wil pull back a few inches, reach in and pull the shift fork off of the throw out bearing. It will be kinda hard but it will pop off so you can slide it back further and drop it down. I did my clutch job on jackstands with a $20 floor jack by myself, so it can be done
Old Nov 24, 2004 | 11:47 PM
Well, I just need to tighten the bolt down on the clutch fork.
Old Nov 25, 2004 | 01:44 PM
OBE1 95Z28's Avatar
Remove the slave cylinder and you'll have access to the end of the clutch fork. Pull the clutch fork out away from the throw out bearing before unbolting the tranny. Be sure to add loctite to the bolt that holds the clutch fork otherwise it will vibrate out later (I found out the hard way). You'll also need to unbolt your shifter from the top of the tranny also, it can be unbolted from under the car, but it's probably easier to remove the console and take it out the top.
Old Nov 25, 2004 | 05:32 PM
zx1216's Avatar
Yea, to get to the bolt you really need to drop the trany, u can get to it with the input shaft still in the clutch but there is not much room to work.
Ericksd
Jan 20, 2016 06:07 PM
Ericksd
Sep 16, 2015 07:08 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
94ZinEdgewater
Sep 8, 2015 09:55 PM
