Compression Test - what is "good"?
Old Nov 24, 2004 | 04:29 PM
72ChevySB's Avatar
I know the general rule where all cylinders should be with 10% of each other, what I cannot find on the net is what a good PSI for a heathly small block Chevy should be.
When my engine is warm with all plug wires off and throttle wide open I get to 150-160 PSI on all cylinders. What I don't know is how "good" this is. I know it means I have a healthy engine but I mean compression ratio wise.
The only clue I could find on the net is chevyhighperformance.com did a test on a small block and called 140psi "dismal" compared to the 190psi on another small block.
Basically what I am looking for is a rough estimate as to my compression ratio since I want to move from 76cc heads to 64cc heads. I am pretty comfortable there though since I have been helped by this board already in that area.
Old Nov 25, 2004 | 03:53 AM
bunker's Avatar
Re: Compression Test - what is "good"?
you can't really tell compression ratio this way because you are measuring cylinder pressure not the compression ratio. Those numbers sound good for an engine with a relatively big cam, cam makes the biggest difference while a difference between cyclinders ussually means bad sealing of valves or leaky rings.
KYWes
Jun 14, 2022 06:52 AM
Quickss96
Jan 29, 2016 05:56 PM
cmsmith
Sep 14, 2015 09:25 PM
karpetcm
Aug 14, 2015 03:02 PM
13qtr
Jul 19, 2015 05:30 PM
