mass air flow sensor
Old Nov 22, 2004 | 09:25 PM
Riderr55's Avatar
What does a mass air flow sensor do?? Does it improve horsepower? Does it Affect drivability? Does it increase gas mileage? Am I asking too many questions??
Old Nov 22, 2004 | 09:32 PM
fly89gta's Avatar
Re: mass air flow sensor
In a nutshell it meters the amount and density(i think) of the air entering the engine so the computer knows how much fuel to add. There can be more technical explainations but that's what it does in layman's terms.
Old Nov 22, 2004 | 09:37 PM
Riderr55's Avatar
So the engine will use up more gas???? Oh one more thing, What grade of octane should I be using in my gas>?? I have a 98 z28 convetable. Is it wise to use a sensor with a cold air induction system
Old Nov 22, 2004 | 10:07 PM
fly89gta's Avatar
I'm a little lost by your questions.
You HAVE to use that sensor or your engine won't run.
As far as octane...I run 93 in my Z..I personally won't use anything less, you might be able tog et away with 89 but I'm not sure.
Old Nov 22, 2004 | 11:39 PM
BirchMan98z's Avatar
using lower octane gas will cause pinging, knock retard, etc, which will affect performance, and could contribute to quicker carbon buildup, as well as a loss of power. Due to the high compression of our engines, it's important to use premium fuel, 91 or 93 octane.
Old Nov 24, 2004 | 03:01 PM
JimMueller's Avatar
Better qualify that comment. If the MAF fails, the car will run in speed density mode. It may not run as smoothly, but it will run.
Old Nov 25, 2004 | 04:13 AM
AL SS590 M6's Avatar
Moderator
Unhook your's and try it. It will run like crap. Forgot to hook mine back up once.
Old Nov 25, 2004 | 09:16 AM
JimMueller's Avatar
When my car was stock, I had a MAF failure. Didn't prevent me from driving it to the dealership for a replacement.
My car hasn't been stock in over 6 years. My MAF is unhooked, and has been unhooked for weeks and it runs great. However, my car is tuned, perhaps yours is not.
Old Nov 25, 2004 | 10:18 AM
DanBUCF's Avatar
So if your car is tuned, you hypothetically don't need a MAF?
Old Nov 25, 2004 | 10:58 AM
JimMueller's Avatar
You can remove the MAF and run speed density tuning (either running open loop full time or regular closed loop). If you want to put the MAF back on afterwards, you may need additional tuning to get your fuel trims back inline.
There doesn't seem to be a lot of folks doing it in the States, but I think that's more a factor of not having the appropriate tools until recently.
Old Nov 25, 2004 | 11:05 AM
DanBUCF's Avatar
Sounds like too much work, I'll keep mine on.
Old Nov 25, 2004 | 02:41 PM
fly89gta's Avatar
Yeah, my bad. Should've been more specific.
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
Fatdog2
Feb 13, 2015 08:19 PM
95chwagon
Jan 13, 2015 09:19 PM
NHSZ28
Jul 25, 2002 07:58 PM
