Can you safely run an STS kit on a stock low miles LT1?
Old Nov 14, 2004 | 02:08 AM
Timmys88Z's Avatar
Just curious. I was looking at the STS kit and think it would be great to have if I could safely run it on a stock LT1 w/o worrying too much about blowing the motor. Its a daily driver so I would need some degree of reliability. The motor is pretty new in the car, about 12k miles on a new GM service engine. And I started running full synthetic in it as soon as I got it (about 3k miles ago) if that even makes a difference...I dunno.
I know our compression is pretty high and not ideal for lots of boost, but can you run 5-7 lbs every day pretty safely? Ok thats it, thanks
Old Nov 14, 2004 | 05:11 AM
97WS6SCharged's Avatar
Re: Can you safely run an STS kit on a stock low miles LT1?
Run it at 5 pounds. Get an intercooler, a BTM box, and ditch the FMU for a bigger fuel pump, some larger injectors, and a tune. That's about as safe as you're going to get with a stock engine and boost.
Old Nov 16, 2004 | 06:47 PM
93formula's Avatar
the sts kit will run fine at 5 lbs, on stock injectors and a tune. no need for a intercooler or meth if your short on cash. the tune would be a must have.
Old Nov 16, 2004 | 07:06 PM
5-liter-eater's Avatar
this is good advice if you can afford it, otherwise a tune and 5psi will work
Old Nov 17, 2004 | 01:11 AM
F8L Z71's Avatar
Too bad I put my truck in the shop or I'd let you check out my kit. I believe I am the only one in Sac right now with an STS kit. There a couple LS1s in the Bay Area with them though.
Old Nov 17, 2004 | 02:30 AM
Timmys88Z's Avatar
Well if I did it it wouldnt be for a while anyway. That would be cool to check out your truck. Let me know.
Thanks.
So... 3 people now say it would be fine at 5lbs and pretty safe? Or is it not a good idea?
Old Nov 17, 2004 | 02:33 AM
93formula's Avatar
5 lbs is fine you have nothign to worry about unless you have cruddy old injectors or a crappy fuel pump.
Old Nov 17, 2004 | 11:38 AM
LukeZ28's Avatar
We ran the system on our stock LT1 for about a year, 3-7psi. Check out our site for info, or throw us an email.
BTW the motor is back in the car after a forged rebuild. Time to crank it up
oldschool
Feb 9, 2016 09:21 PM
Kato
Jan 26, 2015 09:21 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
GigaMp3z
Feb 20, 2003 02:57 PM
Hal Fisher
Sep 14, 2002 09:36 PM
