Getting a ODBI PCM to work on a OBDII car?
Old Nov 11, 2004 | 11:27 PM
mastrdrver's Avatar
I have LT1 edit and the PCM, but what is needed to get it to work on my 97 OBDII car? Does AKMcables.com have all the cables that I need?
thanks
Jeremy
Old Nov 12, 2004 | 09:37 AM
nateh's Avatar
Re: Getting a ODBI PCM to work on a OBDII car?
AKM has the cable you need. The PCM plugs right in but you need to either swap knock sensors to a '95 sensor, or solder a 3.9 kohm resistor between a couple of pins in the OBD1 processor so it reads the '97 knock sensor correctly.
Old Nov 12, 2004 | 12:51 PM
mastrdrver's Avatar
Does the OBDI PCM work with the LT4 knock sensor? The OBDI PCM already has one, but I would prefer to use the LT4 knock sensor over the LT1 sensor is possible.
Jeremy
Old Nov 12, 2004 | 04:29 PM
nateh's Avatar
It isn't whether it's an LT1 or LT4 knock sensor, it's the year. '96 and '97 sensors had a different resistance than the earlier sensors. The PCM needs to see a certain resistance from the sensor. I suspect you're confusing the knock module with the knock sensor. The PCM works fine with the LT4 knock module, you just need to either replace the sensor or wire the PCM to use the earlier computer.
Old Nov 12, 2004 | 11:32 PM
Dan K's Avatar
nateh is right
btw, I've got a conversion pcm for sale
Injuneer
Dec 15, 2014 09:36 AM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
